Results 1 to 15 of 15
Thread: Two speed pump
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    Two speed pump
    Just purchased this to replace my one horse. I hope to save enough on the electric bill to pay for it in three years.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Re: Two speed pump
    That looks good! Please tell us how the install goes.
    22,542
    Re: Two speed pump
    I'd also love to hear how it goes. I plan on changing mine out and that would keep me from having to change any plumbing.
    Jun 2007
    Logan IA
    219
    Re: Two speed pump
    Will do.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Two speed pump
    That is the model and hp I bought in October. It was nice and quiet when I first installed it and then it became loud! Pentaire has a forum on their website where their techs answer questions M-F. After several posts between the tech and I he determined it was a warranty issue and sent a new motor for my pump! Now I just need the time to swap it out.
    I did have a serious rust issue on the bottom of my original pump motor (also Pentair Dynamo) that eventually caused it to fail, and I did see some evidence of rust starting on my current pump motor. I plan to spray some clear finish on the new motor before I install it. I made changes to my equipment pad so water will not pool under the pump motor anymore.
    I have been very happy with the service from Pentaire.
    This is the perfect time to add any valves and unions if you need them!
    Love TFP? Become a
    TFP Supporter!
    Re: Two speed pump
    Could someone explain to me how you would use a 2 speed pump? I get the elecrical use savings, but when do you use the lower speed as opposed to the higher speed?
    22,542
    Re: Two speed pump
    In most cases you only need high speed when vacuuming or backwashing a sand or DE filter, so you run the pump on low all the time except when vacuuming or backwashing. Which is usually a couple hours a day vacuuming & maybe a few minutes per month backwashing.
    Also, with a 2-speed pump you can run it 24/7 on low and still save money over a single speed pump running 8 or more hours a day.
    JoshU's Avatar
    New Orleans, LA
    542
    Re: Two speed pump
    Quote Originally Posted by zea3
    Your mechanical seal probably failed and began to sling water into the motor. I always tell pool owners to check for any small leaks between the motor and pump housing (along the motor shaft). If one develops replace the seal.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    Re: Two speed pump
    If you don't mind, may I ask where you purchased it from? I have the same pool set up but with a 2hp and would love to change it to this pump.
    Thanks!
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    Jul 2009
    Houston, Texas
    9,376
    Re: Two speed pump
    Quote Originally Posted by esim13
    Thanks!
    Mine came from poolcenter.com.
    Love TFP? Become a
    TFP Supporter!
    esim13's Avatar
    Oct 2009
    320
    Re: Two speed pump
    So what's the deal with 'no cord'?
    GEAUX TIGERS!
    Pics taken 2012
    Jul 2009
    Houston, Texas
    9,376
    Re: Two speed pump
    No idea why everyone sells them this way, but attaching a power cord was easy. You can go to a Lowe's or Home Depot and look for replacement power cords. I think you need at least a 15 amp cord. It will say on the pump how many amps it is and you will need a cord rated for that amperage. You will also need a box of female quick connects rated for the same amperage as the power cord. You will crimp these onto the power cord so pick up a good set of pliers if you don't have one.
    Love TFP? Become a
    TFP Supporter!
    22,542
    Re: Two speed pump
    Some people hard wire the pump, some have straight blade plugs (standard receptacle) & some have twist lock receptacles. So instead of having a lot of different part numbers they just sell the cord separately.
    Bought an electric clothes dryer lately? They don't come with cords either! Crazy huh?
    Jun 2007
    Logan IA
    219
    Re: Two speed pump
    Thanks!
    Got mine from here also.....but it's on backorder.
    Jul 2009
    Houston, Texas
    9,376
    Re: Two speed pump
    Hi Josh,
    The rust on the original pump started on the mounting brackets. Those eventually rusted through and apparently kept on going through the bottom of the motor casing. It never did leak. The 2 speed I replaced it with began to run loud after the first cold snap. The only leak I saw there was from the vertical discharge pipe. I have a replacement motor and a new seal, so we'll see how that goes when I have time to get into it. If you have any suggestions on avoiding rust or swapping motors I'll be happy to listen!
    Quote Originally Posted by JoshU
    Love TFP? Become a
    TFP Supporter!
