Results 1 to 14 of 14
Thread: Chlorination Issue in new pool
    Aug 2010
    Austin, TX
    200
    Everything is up an running now - but we're finding that the puck based chlorinator (rainbow 320) is not working at low flow rates <40GPM. The chamber is not getting flooded, and it seems to be letting air in the system. Any thoughts on a better solution? (It's not likely I am going to convince the PB to install at liquidator).
    Picture of how it's setup now:
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
    Re: Chlorination Issue in new pool
    It sounds like it is either installed incorrectly or is defective. Since the pool is new, you should have the builder come out and fix it.
    The water has two other paths it can take instead of going through the pipe that the chlorinator is attached to. This can cause there to be less water flow than necessary for the chlorinator to operate.
    I would also caution you that it is not a good idea to use trichlor as your primary source of chlorine.
    Support the site
    Aug 2010
    Austin, TX
    200
    They plan to, but don't have experience with low flow rate systems. Does seem like the unit is defective to me though.
    Aug 2010
    Austin, TX
    200
    Quote Originally Posted by JamesW
    Are you referring to the CYA buildup caused by trichlor?
    Do you know if the liquidator works with lower flow rates? My assume is yes, but the data is hard to find - may be a question for that forum instead. Jason - I'm cool with moving this thread to the Liquidator section.
    Moved, as requested. JasonLion
    22,553
    Yes, the liquidator will work at very low flow rates. The only requirement is that the pump creates some negative head so it'll draw the chlorine out of the LQ. Even if it creates almost no negative head there are a few ways of overcoming that. A venturi tee or connecting the LQ out line to the pump drain plug port.
    Aug 2010
    Austin, TX
    200
    Alright, I have one on order. I've been lucky - the pool has been seriously low on chlorine for a couple weeks - the UV unit seems to be helping keep the algae at bay.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    Nice looking setup-----------almost looks like a nuclear facility!
    Aug 2010
    Austin, TX
    200
    Quote Originally Posted by woodyp
    Yeah, in the end it may have been easier to run three bodies of water with three pumps instead of one VSP. Had to use 6 actuators...
    Mar 2011
    441
    Quote Originally Posted by shakenbake
    I'm not a real big fan of the swing check valve being installed on its side like that. Typically its best to have the swing direction to work with gravity.
    20X40 30,000 gallon gunite pool
    Mar 2011
    441
    Why 6? Are you trying to maintain 3 different temperatures?
    Pool/spa/wader
    Should only need 2-3
    Aug 2010
    Austin, TX
    200
    Quote Originally Posted by racket
    Pool/spa/wader
    1) Pool/Spa return
    2) Pool/Spa drain
    3) Heat-pump only (running low flow rates, we're getting the best flow out of parrallel gas/heat pump circuit, but I shunt all flow through heat pump when I use it to get best flow at lowest power)
    4) Fountains on/off
    5) Chiller returns on/off
    6) Kiddie/Spa drain (lets us heat both spa and kiddie pool)
    7) (possibly will add) Fountain via spa circuit when spa on (kids asking for it)
    Ottawa, ON, Canada
    153
    1) Pool/Spa return
    2) Pool/Spa drain
    4) Fountains on/off
    Ah man. you missed a perfect opportunity. You should really have added something like "torus", "primary containment vessel", used rods pool, ..
    19.5k gallons in ground, P4 panel with turbocell SWG, 1hp Hayward superpump II, sand filter, Heater low nox 250k btu heater, solar cover on rocky roller
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Many people use trichlor - as long as you understand WHAT it is and WHAT it puts in your pool, and how to correctly deal with the effects of using trichlor. It's also slightly more expensive, but convenient. It's a personal choice, really. If it's its simply a matter of a defective unit and you want to keep using it, the choice is your's. You just have to monitor your levels and keep the PH/TA in check.
