Thread: Pump pad slightly below water level?
    Jun 2010
    Austin, TX
    32
    I'm getting a small exercise pool installed. I guess some might call it a spool. It is 8 x 17 x 5. Once you remove the volume taken by the steps and bench it is only about 3900 gallons.
    I am getting the pool installed raised slightly. The water level will be equal or less than 18 inches above ground. I just now realized that means my equipment pad and equipment will also be slightly under the water level as well. This had not occured to me until I was reading another post about pads below water level.
    Is this something I should worry about? Should I consider raising the pad and equipment above water level?
    3900 Gallon (18 x 8.5 x 5) Partially In Ground Fiberglass Pool -- 2" Schedule 40 PVC -- Hayward P4 Controller -- Goldline Aqua Rite Turbo Cell Salt Chlorinator -- Hayward 2 Speed Max Flo II 1 HP Pump -- Hayward SwimClear 225 sqft Cartridge Filter -- Hayward 250K BTU Natural Gas Heater -- Endless Pool Fastlane Swim Machine -- Cover Pools Manual Track & Reel Security Cover -- TF-100 Testkit
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Pump pad slightly below water level?
    IMO, don't worry about it. Like in the other thread this may mean a few extra valves, but it's no different than dealing with an AG pool and your volume is quite small, so risk of losing a ton of water is not that great
