Thread: Raypac Vs Mastertemp
    We are building a new pool with all Pentair equipment except for the 400btu heater I have read on here that the Raypac is better. My question is around the automation into the Inteltouch system would we gain anything automation wise by going with a Pentair heater?
    In ground Pool and spa Specification
    Free form
    18000 Gallons
    7 person spa¬*
    Tr100 Sand filter
    Pacific Blue Hydrozo plaster
    1 3050VS for pool and spa¬*
    Raypac 400btu
    Polairs 280 with booster pump
    Inteli touch automation¬*
    3 Pentair LED's
    Aug 2010
    Austin, TX
    200
    Re: Raypac Vs Mastertemp
    I don't have experience with intellitouch or pentair heaters, but on Jandy Aqualink and a LXi/digital controls based heater that conects via an RS485 serial interface, you gain the ability to see error codes and messages within the control interface in the house, and the unit "fails" faster - meaning the control system will not continually try to start the heater. A normal interface with a heater is just a dumb relay or fireman's switch, so there is no way for the control system to know if the heater is work except to watch for a temp rise. If the pentair heater connects to the intellitouch via a serial interface and not a simple relay, then I'd expect it to work the same way as the Aqualink + Lxi.
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
    South Central NJ
    3,192
    When equipping a new pad, most pros (myself included) will stick with one vendor so the owner gets the benefit of the extended warranty. As for which is the better heater, both are excellent units. When I am replacing just the heater, I use Rheem (rebadged Ray Pak) as they are usually a little less expensive to the homeowner.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2011
    441
    Quote Originally Posted by PoolGuyNJ
    Scott
    I used to do the same, but Raypak turned into parts NAZI's. Nothing worse than being the installer of something that breaks, and having to pay for replacement parts out of pocket.
    Pentair's heater has a pretty low failure rate, when properly installed.
    20X40 30,000 gallon gunite pool
