TFP Team:
I recently purchased the Taylor SampleSizer. This thing rocks and is the perfect compliment to the Taylor Speedstir since the speedstir comes with the 9198 tube.
Taylor SampleSizer
Saves testing time and aggravation.
TFP Team:
Taylor SampleSizer
Pentair WhisperFlo WFDS-4 - Pentair Tagelus TA 100D
16x32 Vinyl Rectangle 3.5 to 8 ft deep - One skimmer, One dedicated suction, three returns - 2" PVC
Poolvergnuegen Two Wheel Suction Cleaner - One Poolskim
Inter-Fab T7 Diving Board w/Edgewater Assy - Four Pentair Deck Jets - Intermatic T10604R
Circupool RJ45 - Taylor K-2006 Test Kit (purchased prior to learning of the TF-100, unfortunately)
Kinda nifty.![]()
Neat idea.
Watch the video here and notice how the lady holds the sample vial to check the level. She has it tilted toward her, messing up the measurement.
I have to admit, I do like it. I use a 10ml graduated syringe right now but it has it's issues. I may have to try the sizer.
Good notice on the tilted vial John.
Bama, what don't you like about the syringe? I was thinking of using one to measure my samples.
19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
The Pool Cleaner 4x, PoolSkim
I do like it, but when you're sizing the sample the plunger resistance sometimes causes you to overshoot the mark (undershoot the amount) and you have to draw water back into it and do it again. I have two of the syringes and they're both kinda hard to adjust. Different syringes may not have that problem. Even at that, it's way better than trying to sight the meniscus in the vial but it has it's drawbacks.
I agree. I had to get this thing because I kept emptying out too much water or not enough. Now I don't even have to think about it...this thing saves so much time.
15k gunite pool. Intelliflo VF. Autopilot SWG.
2k separate spa with waterfall (ie: pain in the rear maintaining a separate body of water). 2HP Hayward Tristar pump.
Neat. I might want to get one. Where did you get it? Does the TFTestKits have them?
I just use an old r-0013 bottle to fill the test tube. The opening is large enough that if you squeeze the bottle underwater and get enough for 2 samples and let's you add drops until the water reaches the 10 or 25ml mark.
Although I must admit that Samplesizer does look cool
I am such a sucker for neat gadgets. I sorta' blew them off when they first came out but have been reading this thread and, well, I have to have one now.Does the TFTestKits have them?
We will have them on the website over the weekend but not be able to bring them into stock until Wednesday or Thursday....assuming Taylor has stock available for us on Monday AM
Good Morning Dave.
I'll definitely be ordering a couple of those.![]()
I wants one too! When one of you get one please post back here to give your impression of its accuracy vs using a dropper... :P
20K gal IG plaster pool, Manually chlorinated with 6% bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
