I don't know why this is eating at me so much. I am a little obsessive about such things. I have certainly learned a lot about how these systems work thanks to the forum.
I am starting to suspect that I have a suction leak of some sort. It seems that air continues to build in the filter and I can hear it in the heater manifold, particularly at lower speeds. Should the filter develop air over time. I can bleed it, then go out the next day and turn the air valve, air will escape then water comes out again. This quiets the water in the heater manifold. I know the Ozone systems adds small amounts of air, but should that not dissolve in the pump?
I posted in the Pentair innovation forum and a pentair guy said it sounds like air in the system. The pump always has a bubble at the top of the glass, and I do see some air bubbles spinning in the water, I assume from the Ozone. I might try to purge it really well, shut off the ozone and see if air builds up again.
There are more details about the plumbing in this thread that I used for the build:
http://ths.gardenweb.com/forums/load/po ... 16151.html
