Results 1 to 9 of 9
Thread: Pool Equiment upgrade
    Hello,
    We need to redo the pool ( equipment and surface) and after identifying the existing plumbing ( by cutting off pipes and blowing air through each one) – see attached diagram- we are faced with making connections for the new equipment.
    Former setup: 1 WhisperFlo 1.5hp , 1 pump (Century) for pool cleaner, 1 pump (Purex) for spa jets, 2 mechanical clocks, filter (DE, broken), missing heater
    New equipment: 1 Intelliflo 4x160 (3050), EasyTouch 4 + IC40, Sta-Rite SR400NA Max-E-Therm heater, Hayward C4025 filter
    The challenge (one of them) is finding the best way to make the connections so that I can switch from Spa to Pool and back. The pool doesn’t normally get heated but I’d like to have the option to heat it up if needed ( most probably this should be done through a proper setup of the EasyTouch- to allow heater turn on , manually).
    A friend of mine told me the 1” lines I have ( previously used by the booster pump for the pool cleaner) won’t be good enough for a suction or pressure side pool cleaner to work properly ( Poolvergnuegen 4x Suction Pool Cleaner or Pentair Kreepy Krauly Legend II ). Is this true? If so, what are my options?
    Another issue ( like there aren’t enough already) is the lights. I discovered that old pool & spa lights(both same size-pool) (Purex CHD Pool Star) are using 120V /500W standard socket bulbs and I could upgrade to LED-s like ColorSplash 3G easily. However, after buying new lens gaskets I noticed that the black seal at the bottom of the fixture ( around the bulb socket) is cracked and started melting due to sitting in the sun. The lights are working fine, so if the cracked black goo is not a problem and if I can find a place online to buy 1 (out of 6) faceplate screw, I could be saving about $600 or more. Are there any issues/ disadvantages, mostly form a safety perspective, with keeping the old fixtures? This is a ~10 years old pool. What is the life of a pool light?
    Any advice is appreciated!Thanks in advance!
    Lee
    34,000 gal Pool & Spa combination, IntelliFlo 3050 (4 x 160) pump
    ET4 + IC40, Sta-rite heater, Hayward cartridge filter
    Re: Pool Equiment upgrade
    Welcome to TFP!
    A standard shared equipment setup is the simplest way to go. You can program the EasyTouch so it won't heat the pool unless you manually turn the heat on. There are some good plumbing diagrams on this page. The first one is a good place to start.
    a 1" pipe is just fine for a booster pump driven presure side cleaner. It is marginal for pressure side cleaner running off the main pump. It is too small for a suction side cleaner.
    I'm not sure about the light. Seeing a picture would help clarify things. The fixture should last longer than 10 years.
    Thanks for the reply! I will take some pics as soon as I get home and will try to load them tonight. I am trying to take full advantage of the IntelliFlo and was hoping I won't have to use a booster pump for the cleaner. However that does explain the old setup with the small pump connected to the 1" pipes! By the way, I've heard of a Y installed at the skimmer. Will this should allow the suction side cleaner to run using the main pump while keeping the skimmer functional?
    Lee
    Attached are the old light fixtures. As I mentioned, the black "thing" started dripping only after I took them out from the niche and left them on the side of the pool. I protected them from the heat as soon as I noticed what happend. They are still working and I expect I should be able to clean them a little bit before installing them. Again, I am looking at installing new JJ CoolSplash 3G bulbs (standard Edison base).
    The spa is flowing into the pool ....does this mean it has a waterfall ? Or does this depend on the plumbing of the equipment? If so, I need to look at the pool with waterfall diagram.
    Thank you!
    Lee
    Jan 2011
    153
    I would get rid of the Hayward filter and go with a Pentair so all the equipment match and if it's all Pentair you get a 3 year warranty....
    What about the pool cleaner: what would be the best setup? Previously, the two 1 in lines were used by a Polaris pump ( and cleaner I assume, because I haven't seen it). Should I just plug the 1 in lines and use the skimmer (with TEE) with the intelliFlo for the cleaner? If I install a TEE at the skimmer, what pool cleaner ( with a bag) is best (price is important too!)
    Will Pentair Legend II work with my 1 in lines?
    http://www.poolplaza.com/P-LET-20-209.html
    Any recommendations?
    Lee
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I think any pressure-side cleaner designed to work with a booster pump would be OK with 1" lines...someone correct me if I'm wrong. Using a T at the skimmer is not the best of ideas, and no suction side cleaner will have a debris bag; it will all end up in your filter.
    The Pentair Legend II doesn't need a booster pump. Therefore, I was hoping I can run the cleaner without the booster pump- use the IntelliFlo to run that as well. Will it work? If so, is that the right way to do it?
    Lee
    Oct 2009
    3,899
    OK, I see. 1" lines may be a little small for that, but I can't help further.
