Thread: How Much Should A Salt Sensor Cost?
    Hi, My pool guy just quoted me $575 to replace a salt sensor which is used to read, diagnose and activate my chlorinator. This seems excessive. Where can you buy the older style thread type sensors? Is this an easy or hard thing to install yourself?
    30 K gal, In ground
    plaster/gunite pool
    Pump: Pentair Challenger 1 1/2 HSP
    Filter: DE Purex Triton Nautilus FSN-48
    Pentair Automatic Chlorine/Bromine In Line Feeder
    Heater: Raypak
    Dallas, Texas
    Re: How Much Should A Salt Sensor Cost?
    Welcome to TFP!
    A salt sensor is usually under $100, plus something for the install. $575 seems excessive. That is about right for replacing the main circuit board, but they should have said that if that was what they were doing. I can't give you a more detailed answer unless you tell us what brand and model of SWG you have.
    Thanks for the prompt reply. The chlorinator is a Jandy, AquaPure 1400. He did not say if the in-line sensor was bad or something more severe like the circuit board. Does that help?
    30 K gal, In ground
    plaster/gunite pool
    Heater: Raypak
    Dallas, Texas
    susa's Avatar
    Oct 2010
    Deep South
    578
    >> AquaPure 1400.
    entire kit with all parts here is 575, just the sensor should be a fraction
    Jan 2011
    153
    When you say old style threaded sensor it makes me think you have a jandy aquapure.. If that's the case a sensor at wholesale cost is 172.00... A sensor is real easy to install in most cases..
