Results 1 to 16 of 16
Thread: Custom skimmer lids? (Pic)
    Aug 2010
    MA
    173
    Anyone know where I might be able to obtain a square version of this?
    Completed: June 2011
    18' X 38' IG Vinyl, 3' - 8' depth ~ 24K gallons
    2 skimmers, 2 wall suctions, 3 returns, 1.5" piping
    Hayward Equipment: 1HP Tri-star 2-speed, Aqua-Plus SWG,
    Star-Clear Plus 175 sqft cartridge filter, Colorlogic 4.0 LED
    The Pool Cleaner 4X(suction)
    2011 Jacuzzi J-280 Hot tub
    Mar 2011
    441
    Re: Custom skimmer lids? (Pic)
    Someone Put a lot of working in getting a square peg into a round hole.
    You can make your own out of a square paver stone.
    There is no need to have the plastic portions of the lid.
    20X40 30,000 gallon gunite pool
    JoshU's Avatar
    New Orleans, LA
    543
    These guys make a round version but not square: http://www.pouralid.com/products.htm
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Mar 2007
    Coastalish 'down easter'
    4,160
    I don't know who makes one, but I recall (30+ years ago ) making molded plastic ashtrays, etc. in 7TH grade shop class.
    If shop classes are still doing that stuff, all you'd need do is make the right form and do your own
    Luv& Luk
    -Ted
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I know this is OT, but personaly I think the PB (pool or paver guy) did a nice job with that lid...yes it's noticable, but heck after a few brewski's I'd probably had pulled up the entire patio before I found the lid that looks like the rest of the pavers
    Dec 2009
    Central Massachusetts
    2,690
    Have you picked your pavers yet? That skimmer lid is usually the last thing. FWIW, most dont do anything like that.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Aug 2010
    MA
    173
    Quote Originally Posted by bk406
    Yes, I have. Same as what is used in that pic of the custom lid I posted. Blu 60 by Techo-bloc. I do not expect the installer to make the lid, I plan on doing it myself. I just need the right product. Basically what I need is something like what JoshU suggested, only square:
    Quote Originally Posted by racket
    That might be an option, too. So just cut the paver to fit in place of the lid?
    Not sure if I understand what you are going for? BTW, I think that looks great and the pool guy can find the skimmer. Make it square like a paver, and he is going to charge overtime for finding the skimmer every trip.
    Is the skimmer port not round all the way to the top and designed only for a round lid? I guess if its not flush (like my round one), you could just use a paver with an aluminum or stainless back plate on it. This suggestion would work for those type skimmer lids that go down into wood decks and protrude down and are not flush. If yours is that way, who needs a lid under the paver?
    I know Hayward used to make square lids as my older pool has one. The skimmer is round and comes up a round tube, but when it gets two inches from the top, it flares out from round into a square that is just slightly larger then the tube diameter. The lid is flat and fits into the square recess.
    Pool #1 IG 24k Diamond Brite plaster with spill-over spa. Jandy Aqua Link RS One Touch with built into pool floor cleaner. Jacuzzi Magnum pump/basket feeding Hayward top mount Zeosand filter. Jacuzzi Magnum pump/basket for Spa Jets. Heat Siphon pool heat pump. Dolphin Robotic pool cleaner.
    Pool #2 IG 35K 20X40 Vinyl. Hayward top mount Zeosand filter with Pentair 3 HP IntelliFlo VS+SVRS. Chemical Free pool using Water Doctor Copper Ion Generator, PoolSkim, Polaris 9300 Sport robotic pool cleaner, Heat Siphon pool heat pump, solar blanket, Ameri-Dome 50X30 dome enclosure during Winter.
    Mar 2011
    441
    Quote Originally Posted by mx702
    Yes, it makes it look nice, and you can cut a couple in case one gets broken.
    You only have to tell the pool guy where it is once. Then again, they should be smart enough to find it based on the location of the skimmer throat.
    Dec 2009
    2,690
    Why would they need to know?
    Somebody besides the owner sometimes has to get the frogs and chipmunks out of the skimmer basket! ;=}
    With all the heavy rain we had last week, there were two moles in the basket when I cleaned it out.
    mx - did you ever do this skimmer lid? I ask because I am about to pull the trigger on BLU 60 myself
    16 x 42 x 24 IG Vinyl True-L, 27,000 gallons, full width steel steps, 8' Cuddle cove swimout, 2 X Colorlogic 4.0 LEDs, Hayward Tristar 1 hp 2-speed pump, Hayward SwimClear C3025 Cartridge filter, Hayward Aqua-Plus PL-PLUS Controls + Chlorination, Hayward low-Nox 400K BTU heater, Tigershark QC, TF-100 test kit
    Get a maker bot and you can make your own skimmer tops with a rectangle slot for the stone. Then cut the stone to epoxy onto it.
    http://store.makerbot.com/replicator.html
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    Aug 2010
    MA
    173
    Quote Originally Posted by BigJD
    I did not. I couldn't locate a recessed lid to fit the square skimmer throat the builder used. I did order a couple grey skimmer lids from Hayward that blend in with my pavers somewhat.
    I am wondering if you push the throat low enough could you use the lip to support a square paver cut to fit? The other othion is to get a thin piece of bluestone, cut and drill it ... same effect only thinner
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by iPhone
    Hayward still does this. I'm having one installed that is exactly as you described. I wanted a pour-a-lid but they don't make them square.
    I'm thinking I could make a form and pour a new lid when they pour my deck, but it would have to be an exact replica of the square lid, which mean the outer most edge of the lid would be very thin like 1/4" or less, i need to measure.
    To make the form i was thinking sand mixed with elmers glue in a box, cover lid with aluminum foil, press lid into sand, let dry. Then remove lid, recover with aluminum foil, fill with concrete, float it, brush it (have the concrete guys do that)....they can stick a wood dowel in it for finger hole.
    I'm just not sure it would be strong enough....
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
