Thread: Pool paint for drain and returns?
    Jul 2010
    Austin TX
    27
    We have sand-colored pebble plaster in our new pool, and I would like to paint the returns and drains with something that would stick to the plastic and won't bleach out. My plan is to remove the external parts, paint them and replace them after they are cured. So, how about epoxy pool paint? Anybody have any thoughts about whether it would bond well to the plastic, or if this is just too dumb to try?
    Thanks!
    Bill Long
    Bill Long
    Jack of all trades / Master of none
    14,000 gal. 34'X12' gunite w/SunStone quartz aggregate plaster, Hayward 425sf cartridge filter, IntelliFlo VS-3050 pump, IntelliChlor IC-40 SWCG, EasyTouch controller, Polaris 280 cleaner (w/booster), Rheem 5350 heat pump, PoolSkim
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Pool paint for drain and returns?
    My thought, w/o much experience is using fine sand paper to prep the plastic and spray the pieces with Fusion Paint from Krylon. I know it adheres pretty well to PVC, just not sure how it would hold up in chlorinated water
    Are they really so expensive that paint is a better choice over replacement?
    17k in-ground, Pebble Sheen finish (Blue Granite), Solar, two skimmers, split drain.
    IntelliPro VS-3050, IntelliChlor IC40, EasyTouch 4 control system, Easy Touch wired indoor panel.
    300 CuFt cartridge filter. Polaris 380 with booster pump. Two IntelliBrite 5G lights.
    TF100 test kit.
    Jul 2010
    Austin TX
    27
    Yes, dmanb2b, I think the real question is whether the chlorine would bleach out the pigments in the paint, so that is why I was thinking about "pool paint" since it is made to be submerged in chlorinated water.
    As far as replacement vs paint, I guess I assumed that all that stuff is only available in white. But I just Googled and see that most drain cover brands are available in other colors--I just never thought to check! So, I will ask my PB about the brand, and maybe they will even swap them out for me! Not sure about the returns, but will find that out, too. Thanks for the suggestion, Folsom!
    Bill Long
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by FolsomEJ
    See what happens when us DIY folk try answering or coming up with solutions that already exist
    Mar 2011
    441
    Quote Originally Posted by dmanb2b
    Everytime we paint fittings they seem to last long enough to get us paid.
    In the average pool you really shoudlnt need more than $30 worth of colored fittings. Aquastar makes the most colors AFAIK.
    20X40 30,000 gallon gunite pool
