Thread: Automatic Water Leveler
    Has anyone use any of these products? They are the little boxes that hang over the side of the pool and connect to a hose to keep the water level at a certain level?
    It's still hot here and evaporation is causing a problem. I'm going away for a weekend and I don't want the pump to start pumping air if the water level drops.
    Thanks!
    14,000 Gal. IG Plaster
    Hayward S244T Sand Filter W/ 1 1/2 HP Pump
    Hayward Pool Vav Ultra
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Thought about it but found that my evaporation rate drops to nearly nothing if I keep it covered with the solar blanket when not using it.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Thanks for your response. I did go and buy a pool cover instead so I'll see how this works out.
    Thanks!
    Feb 2008
    45
    I live in central/northern california, and I have found an automatic leveler to be a lifesaver. The aftermarket ones, like what you mentioned, are a little ugly, but they can really help. A cover on the pool will help a lot as well, but they can be a lot of hassle. Using both would be ideal.
