Results 1 to 14 of 14
Thread: Help opening my pool
    Rubygrrl's Avatar
    Wichita Falls, Texas
    122
    Hello everyone!
    My pool is super green, and I wanted advice on how to open my pool properly. I own the trouble free test kit, have read pool school numerous time, and have visited here before. I know what to do, I just don't know what order to do things in.
    **My most important question, is that my pool gets direct sunlight all day. I have no trees or anything else that gives any type of shade to my pool. I've always followed the "recommended levels" in pool school, but I was wondering if I should change a few of the recommendations since my pool is in direct sunlight all day. What do you all think?
    Here are my test results so far:
    CYA: 25
    FC: 0
    CC: 0
    TC: 0
    pH: VERY HOT PINK...I'd say 9.0 (off the charts).
    Alk: 80
    **I have a liner pool, sand filter, and a 1 1/2 hp pump**
    Here is what I was going to do in order:
    1. Shock pool to 11 FC using 6% liquid bleach (and I know some of you all maybe against this, but I may use a bit of calcium hypo just to speed up the process, but certainly not any trichlor). Brush walls and floors of pool at least once a day and maintain 11 FC throughout the day.
    2. Decrease pH (once my chlorine level falls to about 4 or so) by adding about 36 oz of muriatic acid.
    3. Recheck Alkalinity levels and adjust if needed.
    4. Increase CYA to about 40 (since it's low).
    Would you recommend I follow this order, or do something differently.
    Thank you so much for all of your help!
    Emily
    In-Ground Vinyl Pool
    21,000 gallons
    Sand Filter
    1 1/2 hp pump
    Rubygrrl's Avatar
    122
    Re: Help my opening my pool
    I forgot to mention that I will also do an overnight test to make sure it is algae..but it's got to be...pool looks like a swamp!
    21,000 gallons
    Sand Filter
    1 1/2 hp pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,575
    That sounds like a plan. I keep my CYA at 50 in summer and still lose 3.5 to 4 ppm per day in the heat. I bump it up to 8 and it gets right at back down to 4 which is the minimum for that CYA level. So mine eats a gallon of 6% on average hot days. Since you have zero FC at the moment, it wouldn't hurt to go ahead and bring that ph down to 7.5 before you start "spiking" your chlorine level.
    Rubygrrl's Avatar
    122
    Ok! Thank you so much! I will go ahead and bring the pH down first before I shock.
    Thanks again!
    21,000 gallons
    Sand Filter
    1 1/2 hp pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Always adjust PH first, before you begin the shocking process as PH readings are inaccurate at high FC levels
    Rubygrrl's Avatar
    122
    Re: Help opening my pool
    Ok..thanks so much!!
    21,000 gallons
    Sand Filter
    1 1/2 hp pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Question - was your filter running before you did the initial testing?
    Do you want your filter running before you do your initial testing?
    22,000 In-Ground Vinyl Fox Pool
    250,000 MiniMax Pentair natural gas heater
    4 returns 1 skimmer 1 main drain
    1hp Hayward Max Flow II single speed
    Sand fox pool Filter
    First year owner of the aforementioned.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Quote Originally Posted by mrpunchy
    Now that's what I call a GOOD question!
    I've always assumed that the water should be thoroughly mixed before you can trust the tests, but I do not have the chem expertise to say that it's a must
    We'll have to see if the chem gurus have any input on this
    Luv& Luk
    -Ted
    I am going to bump this to see if the question gets an answer.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yes, always.
    Thanks!
    Rubygrrl's Avatar
    122
    I'll be honest and say that I don't remember if my pump was running. I know that my timer was on--so it was running for 12 hours on, 12 hours off, but not sure if it was running when I tested the water. I never really knew it needed to be running, but it certainly makes sense that it needs to be!
    It's been a week since I added the CYA, so I am going to recheck all of my levels today. I think my Ph is going to bit a bit low (7.2)---so I'll have to raise that. I hope everything else checks out perfect though. *Fingers crossed*.
    *The good news is that the green algae is all gone. Pool is sparkling/clear!
    21,000 gallons
    Sand Filter
    1 1/2 hp pump
    Mar 2007
    4,160
    That is VERY good news!
    You can do the 'overnight cl loss test' to be sure that all the algae is gone
    Luv& Luk
    -Ted
