Results 1 to 10 of 10
Thread: Kinda wondering....
    Sep 2010
    Noblesville, IN
    104
    Kinda wondering....
    I'm probably a month or so away from opening my pool for the first time and am ready to go chemical shopping. I'm going to do the BBB method this year and am looking for an idea of how much of each chemical I should start the season with. I have storage available and don't want to be going to Walmart every week for Bleach, Baking Soda and Borax.I have no idea how much of these per month I will need. What's a good rule of thumb for an inventory of chemicals to start with?
    16 x 32 15300 gal. IG Vinyl Jandy pump, Jandy sand filter, Paramount circulation system, Automatic pool cover.
    30,419
    Re: Kinda wondering....
    Welcome to the forum I wouldn't buy anything (except maybe Clorox). Your first requirement is to test your water to see where you are and what, if anything, needs to be adjusted.
    You may not need anything else based on the test results of your water. Clorox is a given in that you will consume it all summer....quite a large bit at first.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    And unless that storage space is air conditioned, about a 30 day supply of good old bottled bleach may be all you want to keep on hand at a time--especially as June, July, and August approach.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    I agree. Get around a 30 day supply of bleach. If you have had a lot of pH fluctuation in the past then you might want to keep a bottle of MA around. Otherwise I would check the condition of my vacuum hoses, brushes, and other maintainance equipment to see if anything needs replacing, and invest in some poolside goodies to make my summer more enjoyable!
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    San Rafael, CA USA
    12,082
    You could also check pricing for chlorinating liquid as it might be close to as economical, but is less weight to carry. I buy 12.5% chlorinating liquid from my local pool store where they charge a very reasonable price these days of $3 per gallon and they reuse the bottles which is better than recycling. This pricing is equivalent to getting a 96-ounce (3/4 gallon) bottle of 6% bleach for $1.11 (the "Trade %" for 6% bleach is actually 6.17%).
    Sep 2010
    Noblesville, IN
    104
    Thanks for the info but about how many gallons for a month supply? My pool center has chemicals 15% off until March 20 and I was going to check their pricing on liquid chlorine.
    Jun 2010
    Glendale, CA
    513
    You'll probably use about 1 case a month of 12% chlorine (4 gallons).
    6% bleach will be 6 or 7 of the bigger jugs.
    That's making A LOT of assumptions about your chlorine usage (1 - 1.5ppm per day). It could easily be more than that.
    If you could test a sample of your water - PH and TA - we could at least give you an idea if you might need acid, soda, etc.
    If you are using liquid bleach all season then you'll probably have a PH that rises over time. So some acid will be handy.
    Keep in mind - both chlorine and muriatic acid weaken over time- especially in the heat. So it's a little counter productive to stock up on too much. Take it month by month. Borax, baking soda, CYA are certainly not week to week needs (in quantity).
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    22,548
    I buy about 8 large jugs of bleach a month. The higher percentage the bleach the faster it degrades. 6% is pretty stable for several months. If you buy 12.5% or so I would take the advice above and not keep more than about a months usage on hand. I've kept Muriatic acid for a year and not noticed any degradation in strength It's really stable.
    Sep 2010
    Noblesville, IN
    104
    Thanks. I am going to try the 12% first. Pool store has a case (4 jugs) for $16.99 less 15% this week.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by HoleInOne
    Just FYI. Assuming these jugs are 1 gallon, then this price is equivalent to ($16.99/4)*0.85*(6.17/12)*(3/4) = $1.39 for a 96-ounce (3/4 gallon) jug of 6% bleach or $2.78 for a 1-1/2 gallon jug of 6% bleach.
