Thread: Autopilot LS model with an in-floor cleaning system-Trouble!
    I have a Autopilot LS model with an in-floor cleaning system. I have 2 zones running at the same time, and the pool is not cleaning well. The same thing happened last year and we replaced a meter that regulates it. Perhaps this meter is bad? (does anyone know the name of that thing?) Or, is there another problem? How can I maybe check to see if the meter is working?
    Mike
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Re: Autopilot LS model with an in-floor cleaning system-Trou
    Have you tried backwashing/cleaning the filter?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    2 zones running at the same time sounds like a problem with the geared mechanism ("meter" ??) that rotates to switch between the zones. Can you open up the little canister and take a look at it?
