Thread: How many Intellibrites for 18x36 rectangle?
    Feb 2011
    Cincinnati, Ohio
    106
    Do you think 1 Pentair Intellibrite Color LED in a 18x36 rectangle with deep end and dark blue liner would be enough light to light the pool nicely? If so, where would you place it? PB charges 850 for each so trying to minimize obviously.
    THanks.
    18 x 36 IG Vinyl Liner 28K Gallons
    Pentair Intelliflo VS+SVRS, Pentair CC + 420 Cartridge Filter, Easytouch CP with IC40 SWG
    2" Suction and Return Lines - 2 skimmers, 6 returns
    Dolphin Diagnostic Advantage Robot
    Re: How many Intellibrites for 18x36 rectangle?
    That depends on what you really want. Most people prefer two lights in that situation. One light will work, it just won't be as bright as you are likely to want.
    Placement depends on how many lights and how the pool is laid out. If there is a specific side you normally view the pool from it is often best to put the light(s) on the wall on that side, so you are not looking directly at the light. With one light, most people put it on one of the long walls somewhat centered but closer to the deep end. Wit two lights you can either spread them out along a long wall or put one on each of the short walls.
