what are you using?
Feb 28, 2011
27
What are you guys and gals using to get your CYA levels up and where are you getting it? Unfortunantly the only place close to me with pool supplies is Wal Mart and I'm sure they aren't the best place to buy and I haven't seen any stabilizer there anyway.
It might be labelled as Chlorine Stabilizer. If they don't have it, Lowe's probably does.
Or you can use dichlor shock to chlorinate until your CYA level gets to where your want it.
I just use Tri-chlor pucks untill the CYA is where I want it. I think this is one case where using them is not only justified but preferable. No more bleach until CYA is right. I guess if it was sunny the FC might get used up quickly until CYA was high enough.
