Thread: Changing your pool light. Anyone do it themselves?
    Does anyone change their own light out? Also can you change from a regular halogen bulb to a LED pretty easily or do I need some conversion kit? I currently only have one light but a second one would be nice.
    24,000 Rectangular Vinyl IG, Sand, 1.5 Hayward Pump
    JoshU's Avatar
    New Orleans, LA
    542
    Re: Changing your pool light. Anyone do it themselves?
    Are you trying the change the entire fixture or just the bulb?
    You may be able to with an LED unit. What make/model do you have?
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    I guess the whole thing. I was assuming LED used a different base thing entirely.
    They make LED bulbs that fit many of the common non-LED fixtures. You need to know exactly which fixture you have and then you can check to see if you can find something that is compatible. Changing the bulb is a little bit of a project, usually easy enough if you are DIY inclined and have the correct replacement gasket to use when sealing the fixture back up.
    If there isn't a bulb that fits your current fixture, you will need to find a fixture that will fit in the same niche your current fixture is installed in. That may not be so easy to find, depending on what you have now. Replacing the fixture is more complex, and sometimes leads to difficulties (when the conduit has collapsed). Still, a confident DIY type can handle it.
    Changing the niche that the light is mounted in is very difficult. Most people will want to leave that project to a professional, or more likely make do with what they already have.
