Thread: Winter Damage - Best way to fix
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Hi,
    Just looked at my pool for the first time in months (the snow just melted.)
    I noticed that one of the brass bolts holding my cover down has broken.
    I AM NOT a "do-it-your-selfer."
    What is the proper way to fix this damage? (both structurally and aesthetically)?
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Winter Damage - Best way to fix
    There is a tool sold by wingmaster that removes damaged cover anchors, this one will need to be drilled out then tapped to be removed. The wingmaster device kinda works like a wine bottle opener. Anyways, the tool is too expensive for you to buy to replace only one anchor. You might need to call a pool guy to fix this for you. The concrete is also chipped up and that can be patched with some cement but its unlikely it will match in color. The only other thing that you can do to hide the chips in the concrete is to use the "beauty collar" / escutcheon that goes around the neck of the new anchor to hide some damage.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    To what diameter should it be drilled out for maximum strength?
    Mar 2011
    441
    Quote Originally Posted by kenmar
    I'd patch the old anchor in, and re-locate it a few inches off to the side. You can also move is further or closer to the pool provided the strap will be tight when you hook the spring back up.
    I cant tell what the deck finish/coating is in the but I'd fill the old anchor in with concrete patcher then patch the deck coating with whatever it is.
    I wouldnt buy a tool that removes anchors. Just drill it out with your roto-hammer.
    20X40 30,000 gallon gunite pool
    South Central NJ
    3,192
    A shop vac should suck up the concrete pieces. It might even pull the broken anchor casing up too. If not, a couple of flat head screw drivers should be able to walk the remaining lower half of that casing out. Then fill the hole. It appears to be a simple, brushed, concrete deck. It will look like an off color stain and will slowly blend in over time.
    Drill a new 3/4" hole and set a new anchor. Keep at least 2" away from the old hole for strength.
    That is the 1st time I have ever seen a casing snap off. Usually, it's the top of the threaded insert that shears. I wonder if the casing is even still in the hole . It might have been flipped out in the opposite direction.
    Scott
    Owner of - PoolGuyNJ LLC
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Thanks guys! Like I said, I am not a "do it your selfer". I just want to make sure that the people I get to fix it will do it properly.
    Thanks again!
