Thread: Tell me about my equipment
    Mar 2011
    Houston, TX
    72
    I just called the people who installed my pool in 2007 to get a list of the equipment since I haven't moved in yet. So here is what I have. Tell me what you know about it.
    All equipment is Jandy.
    460 Cartridge Filter
    2 HP pump
    100 w light at Spa
    500 w light at Pool
    Jandy PDA
    400k BTU Heater
    Polaris Cleaner
    Polaris Pump
    Rainbow 320 Chlorinator
    Pool size is +/- 18,000 gallons
    18,500 gallons, Cartridge Filter, In Ground Plaster. Jandy CL460 Filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: Tell me about my equipment
    Hi! I'll add my responses after each item.
    Quote Originally Posted by brownchristian
    This is the filter for your pool. It uses a paper or cloth cartridge as the filter media. You clean it by opening up the filter body, removing the cartridge and hosing it off. If you use a lot of sunscreen you may need to soak the cartridge once of twice a year to remove the oil deposits.
    2 HP pump
    This would be the main water circulation source for the pool. It pumps water to the filter and provides suction to run a manual vacuum or pressure side cleaner.
    100 w light at Spa
    The light in your spa. May be located in the bottom of the spa.
    500 w light at Pool
    The light for the pool, usually located on the side most likely to blind you as you look out the window (j/k )
    Jandy PDA
    PDA= Pool digital assistant. A wireless controller for the pool
    400k BTU Heater
    Your pool heater. Might be just for the spa or might be for the whole pool.
    Polaris Cleaner
    An automatic pool cleaner, run using the polaris pump
    Polaris Pump
    A canister attached to the pool plumbing. It holds chlorine pucks. You should only use it when you plan to be away for more than a couple of days. Also make sure to find out what kind of pucks it had in it last. Dichlor/Trichlor does not play well with Cal-hypo.
    Sounds like a nice set up. I hope this answers your questions. Enjoy the new(to you) pool!
    Love TFP? Become a
    TFP Supporter!
    Mar 2011
    Houston, TX
    72
    Thanks for the info. I guess my question was more about the quality of the equipment. Should I be concerned with any of these parts?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    [quote="brownchristian"] I guess my question was more about the quality of the equipment. [quote]
    Tough to say without specifics, but Polaris and Jandy are quality brands. Rainbow is well known as well.
    eg. a "2HP pump" doesn't tell us much...brand and model # would help draw some opinions
    same with 460 Cart Filter
    I realize you may not have full access to the home yet, but in all you equipment does not look too bad, just do insist on a pool specific inspection, in addition to the home inspection. Good luck with the purchase.
    Jan 2011
    153
    It's mainly all Jandy equipment which is one of the top equipments there is.. The 320 chlorinator is Pentair which again is at the top... Jandy and Pentair are the 2 best companies and can't go wrong with them...
    Mar 2011
    Houston, TX
    72
    Thanks Keven. Thats what I wanted to hear. Now to decide on Salt or Not.
