Thread: Low amps on T3 Aqua Rite Cell..is this normal?
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    just checking. system is working fine and I believe I read somewhere the smaller cells have lower amps.
    Cell Current: 2.21 if my memory is correct. I know its 2.something. I don't log cell current.
    Here is some background info on the pool:
    FC: 3.5
    CC: 0
    PH: 7.5
    TA: 100
    CH: 280
    CYA: 30 (increasing this. don't know how I let it get that low)
    SALT: 3,500
    TEMP: 76
    CSI: -0.24
    SWG%: 45%
    PSI: 20
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Low amps on T3 Aqua Rite Cell..is this normal?
    Yes, for the Goldline cells, the smaller cells will draw less amps and thus produce less chlorine. The T15 draws between 4-8 amps, the T3 should be between 1.5-3 amps.
    Mark
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Quote Originally Posted by mas985
    Thanks Mark. Much appreciated.
