Results 1 to 7 of 7
Thread: Planning new outdoor kitchen in CT.
    Has anyone built a kitchen on a low (5 inches off ground) deck built with Ipe?
    I will use steel studs with hardie backer stucco and granite tile counter top.
    Not really using this as a bar because we have a lot of seating on the pool patio (which is right next to it)
    do i need to elevate the bottom track or will the decking be good enough?
    Thanks I am new so any advice would be great.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Planning new outdoor kitchen in CT.
    I can't offer a whole lot of help, but I'll say I would still elevate it to make sure water doesn't pool underneath it and rot the deck. Good luck! Perhaps one of the pros will stop by and offer some more specific advice. There are lots of island builds here, so look around!
    Thanks. I was thinking of doing that just to make sure.
    I will post pics of my project as I get going!
    Have to build Ipe deck first then Kitchen on top.
    I saw one of the builds i on a deck and he used composite decking.
    Thanks
    what are people using for stucco I see in many of the pictures one coat stucco. Where did you get this? Where is it available???
    Thanks for any responses
    Oct 2009
    3,899
    It's available at any hardware or big box (i.e. Lowe's) store, at least here in Arizona.
    Riles_J's Avatar
    Nashville, TN
    218
    I am building an outdoor kitchen as we speak on an Ipe deck as well. Mine deck is up off the ground about 3-4', but I did put some Ipe pieces under the bottom rail to keep it up off the deck. You can see them in this picture. Forgive the condition of my Ipe, but I am waiting until I finish the kitchen to sand/restain.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    cant see the picture.
    Mine will be 4-5 inches off the ground.
    Thanks for the reply.
    We are getting hit with a bit of snow so my project will be stalled a little bit now.
