Thread: Umbrella inserts
    Nov 2010
    Calera, Al
    271
    Umbrella inserts
    Does anyone or has anyone used these umbrella inserts? We are wanting to install in our decking on pour day. Any insight or suggestions would be appreciated. http://www.poolpartsonline.com/p-740-vo ... older.aspx
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    JoshU's Avatar
    New Orleans, LA
    543
    Re: Umbrella inserts
    Yep, I've used them. Those look like they're made by Waterway. No quality issues or anything to note.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Considering how cheap they are, if i were doing it i'd put one in every place I thought i could possibly want an umbrella. Its much easier to have too few than too many! Make sure to consider sun angle too; i.e. where do I need to have the sleeve in order to have shade in this spot at this time?
    JoshU's Avatar
    New Orleans, LA
    543
    Quote Originally Posted by Melt In The Sun
    And remember you can use them in the deck too.
    Nov 2010
    Calera, Al
    271
    Thanks for the insight. I got four, one for the deck where the lounges will be, two beside the tanning ledge one for morining one on the opposite side for afternoon and one for the swimout bench...
