Custom PVC Pipe Adapter for Intex Pools
If you don't have a lowes nearby and want an adapter from Home Depot, they have one in their PVC irrigation aisle (actually two - slipXslip & slipXscrew) that will work.
Mueller Streamline 1-1/2 in. x 1-1/4 in. PVC Schedule 40 Pressure Spigot x Slip Bushing
Model # 437-212HC
Store SKU # 294292
http://www.homedepot.com/p/Mueller-Stre ... /100165443
They also have one that is slipXslip so you can just slide/glue PVC on each side, but I can't find that on their website.
Similar to the lowes ones, I just sanded off the writing that sticks out of the flush mounting area (I just used the concrete ground I was standing on and it rubbed the letters right off!!! :twisted: ) and then used the DIY rubber gasket sheet from lowes to get a water proof seal (didn't find one of those at HD).
I bought these Muller adapters, but unless I am missing something the flange is not big enough to stay / hold inside the screw nut cut-off the Intex hose. The flange looks notably smaller than the Cantex and Carlon adapters.
Model # 437-212HC
Store SKU # 294292
kf4yag,
Since the post to which I am responding is over a year old, I'm not sure if I'll get a response from kf4yag, but if anyone else can answer my question, I'd be grateful.
I have an Intex Ultra Frame !4' x 48' pool and the Intex 14' sand filter. I would like to add the ball valve to the return jet, like kf4yag did (his pics are above), but I want to use flex hose for the entire length instead of using any of the rigid PVC piping. The problem is, I need a longer flex hose than the standard 6' lengths that are available from Intex. I need it to be at least a 12' length. What do I do?
Thanks for any wisdom anyone can share.
Do the same as kf4yag did except use the same flexible hose for the entire length. You can purchase it at your local hardware store by length.
Or if you want to use Intex hoses then what I will do is use some kind of adapter that you can connect two intex hoses together.
You need to give us more details. Would you use same adapter, elbow and hose as kf4yag? Would you need to bent the hose a lot ? Do you plan to use same adapter,elbow as kf4yag but instead of the hose like he use , you want to use intex hoses?
Hi, Thank you for your reply. I have the basic concept of the construction of the elbow and the connection to the pool return jet as kf47yag and others have described. Here are my questions:
What size ball valve should I use?
How do I attach the flexible Intex hose to the bottom of the ball valve?
kf47yag's flexible hose looks to be about a 4 ft length that then connects rigid PVC pipe that leads to the filter/pump. I do NOT want to use the rigid PVC pipe leading to the filter/pump. Instead, I want to use only flexible hose from the bottom of the ball valve to the Intex pump/filter, but I need about a 12 foot length in order to reach the pump/filter. I only have two 6 ft flexible Intex hoses, so I need to connect those two flexible hoses together. My questions are:
WHICH adapter can be used to connect them together? And where do I get it?
Thank you for your help.
If you want to use ball valve like kf47yag did then it will be easier for you to also use flexible hose like he did, not the intex one. If you want to use intex hoses then you will need to make an adapter to connect these hoses together and also a adapter to connect them to the ball valve. Too much pain in the butt.
I will go with the same flexible hose as kf47yag did. Just use it for the whole length of your set up.
If you already have the adapter and 90 degree elbow like you showed on the picture above then you buy the same size of ball valve and same size of flexible hose. I assume kf47yag have used 1-1/4" ball valve.
So you need ball valve like this one or similar: http://www.homedepot.com/p/LEGEND-V...ocket-Ball-Valve-S-600/203581048#.Ul55wRCFeF8
and PVC flexible hose: http://flexpvc.com/ the link just shows what I'm talking about. You don't have to buy online. Your local hardware store should have 1-1/4" PVC flexible hoses. And you can buy them by foot and they cut it for you.
And you just simply connect everything using PVC cement http://www.homedepot.com/p/Oatey-8-...-Solvent-Cement-302483/100151579#.Ul57uxCFeF8
Let me know what size of plumbing you want to use and then I can help you with the set up. Most of guys are using 1-1/4" or 1-1/2"
Oh, thank you so much for the information! I am really ignorant about what is available and didn't know I could buy flex hose in desired lengths. I thought I had to use what was available through Intex, especially since (from what I can gather), the Intex equipment is odd sized. Later I will do my best to give you greater detail about what I want to accomplish. This confused lady appreciates your help very much. I haven't been able to get much help from the local pool shop (surprise, surprise) or from the guys at Lowes (though they really tried).
Basically what you want to do is pretty straight forward assuming you already have the parts to create custom adapter. Remember you need at least two sets of the custom adapter. If your local store doesn't have flexible pvc piping then you can order from here by the foot: http://www.winterpoolsupplies.com/p...es/flexible-pvc-hose-white-1-1-2in-x-per-foot . There might be cheaper places but I never looked since I never need too. :-D
If I were you I will go with 1-1/2" diameter plumbing, since the adapter is 1-1/2" outside diameter.
For the record for those reading this.......Lowes has the 1 1/2 inch flex pipe that you can buy by the foot. I will highly recommend you spend the $29 for the red handled PVC cutters. They are by all the other PVC cutting stuff. You can use them for not only the flex stuff but they work very, very well for cutting the rigid stuff too. I will never use a saw again....with the cutter, no mess, no fuss.
Other two cents: Get rid of all the Intex parts......go get "real" Hayward pool parts, plumb with wonderful PVC and enjoy the new found flow even using Intex pumps......those PVC ball valves eliminate ALL flow problems.
Bob
Bob
Good advice Bob :goodjob:
Hi, I'm using a 635T filter for JUST my solar heaters and I'm looking to run PVC instead of the hoses. Just to make sure I understand (not an expert by any means!) will the A2656 let me change the inflow hose from the pool to the filter to PVC and the out from the filter to the solar system to pvc?
Thanks!! Suzy
This is for people who don't speak hardware-ese or have a bunch of tools......
Living in Florida, I have to replace the intex hoses a couple times a year because they can't stand up to the sun and salt air, and that's expensive. I decided the simplest solution was to find a substitute for the plastic end on the hoses, in a size and shape that standard inch and a quarter PVC could attach to. That way, I could keep the original strainer and pump etc, and only replace exactly which parts I want to.
http://i1091.photobucket.com/albums... adapter/IntexHoseEnd-picsay1_zps5c0c00e2.jpg
I spent quite a lot of time going to various hardware stores, electrical supply stores, plumbing supply stores, online, ebay, talking to manufacturers, etc. and concluded that nobody makes exactly the right part.
I started with the Carlon "reducer bushing" from home depot in the electrical aisle as suggested in this thread, but HD switched to Cantex, which doesn't work because of the octagonal shape instead of round on the end and because of the thick flange on the end. A standard "electrical box adapter" looks right but the flange on the end is too thick for the threads of the nut to catch once you add a gasket.
I ended up with a combination of plumbing and spa pieces, that don't need any cutting. (Electrical conduit is more expensive than plumbing parts.) You will need an adapter assembly for each end of each hose you are replacing, just count how many places you attach a hose and screw on a hose nut.
You will need the old nuts off intex hoses, they don't sell just the nuts.
http://i1091.photobucket.com/albums...adapter/Reused_intex_hose_nut_zps6bcdb362.jpg
For the piece that replaces the plastic part on the ends of the hose I found Dura 1.5x1.25 inch "reducer bushing" at a spa supply store, they are also available online, they are a dollar or two. This is a smooth round tube with a round flange on the outside of one end and a stopper ring on the inside of the other end.
http://i1091.photobucket.com/albums..._1_5x1_5_inch_reducer_bushing_zps08764e8f.jpg
It's made to put 1.5 inch pipe outside and 1.25 inch pipe inside, but we're going to use it backwards. If you have the tools and know-how, cut off the end with the inside ring and you're done. If not, then for each adapter assembly you need two of the reducer bushings plus a 1.5x1.5 inch "slip x slip coupler" from the plumbing section of any hardware store, they are a dollar or so. What that looks like is a smooth tube, sized so that your PVC pipe slips inside. There's a little ring inside the middle that stops the pipe from just sliding all the way through.
http://i1091.photobucket.com/albums...ter/1_5x1_5_inch_slip_coupler_zps418eac03.jpg
http://i1091.photobucket.com/albums... hose adapter/20140312_142312_zps9beeb33b.jpg
You also need hose gaskets, you can reuse the old ones that came with your pool, or get new ones from intex for a couple of dollars, or find some at a hardware store. I just reused the old ones.
http://i1091.photobucket.com/albums...ed_gasket_from_old_intex_part_zps85bd1566.jpg
*Note, if a spa supply store near you doesn't have a whole lot of the Dura reducer bushings, you can use other ones for the side facing away from the intex piece that you're attaching to. One side has to be exactly the right size and shape and thickness, but the other side can be whatever brand a hardware store has, since it's just going to have standard PVC glued into it.
Put everything together and check it first, before you glue.
First, put the gasket on the connector where the hose normally sits.
http://i1091.photobucket.com/albums...t_the_gasket_on_the_connector_zps0743f730.jpg
Second, put the Dura reducer bushing on top of the gasket with the flange pressing on the gasket.
http://i1091.photobucket.com/albums..._to_1_25_inch_reducer_bushing_zpse082b88d.jpg
Third, slip the hose nut over the bushing and screw it on, making sure it is straight and tight. The bushing should not move around once the nut is tightened.
http://i1091.photobucket.com/albums...er/Third_put_the_nut_on_tight_zps93b1aa6b.jpg
Fourth, put one end of the slip coupling onto the reducer bushing.
http://i1091.photobucket.com/albums...the_1_5x1_5_inch_slip_coupler_zps5ddb12f2.jpg
Fifth, put another reducer in the other end of the slip coupler facing the opposite direction.
http://i1091.photobucket.com/albums...1_5x1_25_inch_reducer_bushing_zpsbbe0dd34.jpg
Sixth, add 1.25 inch PVC.
http://i1091.photobucket.com/albums...inally_add_1_25_inch_pvc_pipe_zpse3824a68.jpg
Once you're happy with the layout and fit, glue the PVC pieces together using plumbing primer and glue, they usually come in a box together for five to seven dollars. **Don't glue the Dura bushing to the gasket!**
When it's set and dried, test it under pressure and look for leaks. If it leaks right at the hose nut, you might have to fiddle around with getting the gasket centered, or you might have to smooth/sand the end of the Dura bushing if it's one with raised letters.
If your pool has flexible sides, you will need at least a short piece of flex PVC at each connection that might move. Flex PVC can be glued into regular PVC fittings, that's what it's made for. You can find it at a spa or hardware store, or search online for flex PVC. It's more expensive, so to keep the cost down you could just use a couple feet right where the joints might need to move rather than everywhere.
http://i1091.photobucket.com/albums... adapter/Flexible_pvc-picsay1_zpsb2ec230c.jpg
Several helpful people have posted some amazing designs elsewhere on this site with ball valves etc. for laying out your system depending on what pieces you have, filter, skimmer, vacuum, fountain, etc etc.
Hey Raaza,
Sir two questions.
1. When you used those 1.5" conduit bushings did you reuse the original Intex flexible hose screw-on couplers to tighten/screw onto the Intex plunger valves?
2. Did you simply push the 1.5" conduit bushings over the plunger valve and seal with the plunger's original o-ring or did you buy a bigger 1 & 1/8" o-ring and seal the two up at their top mating faces? Reason I ask is I tried a spare piece of 1.5" conduit and it seemd soo tight that it pushed the plunger's o-ring out of it's recessed sealing surface.
David
