Thread: First Time Opening
    Lehigh Valley, Pennsylvania
    71
    First Time Opening
    This year is going to be my first time opening my pool. What is the order for balancing the chemicals that I should follow? Do I add the bleach first and take it to shock and the worry about balancing the rest (CYA, pH, etc.) or is it the other way around?
    Thanks!
    25K gal vinyl inground, 1HP Hayward Pump, Hayward DE 4820 Filter
    22,553
    Re: First Time Opening
    The first thing you need to do is run a full set of tests. That will tell you what needs adjusting. My FC was still over 7ppm when I opened so I adjusted pH first.
