Thread: Accessing Aqualink RS12 aux JVAs
    Aug 2010
    Austin, TX
    200
    On the touch and onetouch I only see a way to assign the 4 primary JVAs (cleaner, solar, return, suction). There are 4 aux jva connectors on the RS12's expansion board that i need to use but don't see on my touch - any thoughts? I do see the expansion board's aux power relays.
    tia
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
    Re: Accessing Aqualink RS12 aux JVAs
    From the users manual:
    Assign JVA Menu
    The ASSIGN JVAs menu allows Jandy Valve Actuators (JVAs) to be assigned to any auxiliary button. This means that
    whenever you press that auxiliary button, a valve turns. On pool/spa combination models, there are two extra JVAs
    that can be assigned to auxiliary buttons: the cleaner JVA and the solar JVA. On pool/spa only models, there are four
    JVAs that can be assigned to auxiliary buttons. The installer must set these JVAs for this feature to operate correctly.
    Assigning JVAs lets the owner control certain features like diverting water to a waterfall or bank of spa jets. Multiple
    JVAs can be assigned to one auxiliary button without extra hardware.
    I am not sure what that "installer" action is, but it shouldn't be too difficult to figure out.
    Aug 2010
    Austin, TX
    200
    Assign JVA Menu
    Thanks Jason!
