Thread: Impeller housing
    Impeller housing
    I have a question about impeller housings-
    Are the housings interchangeable between different
    brands of motors.
    thanks for any help
    regards
    fogger
    Re: Impeller housing
    Welcome to TFP!
    It depends on what you mean. Often you can swap motors between pumps. But the impeller housing alone, without the impeller, can't be swapped unless you stay within a single model line.
    Thanks Jason,
    I swapped the impeller and the housing-just was not sure.
    Working good now-have happy koi
    thank you
    fogger
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Jason gave the same answer as I did on 'the other site'
    Luv& Luk
    -Ted
