We are putting in a 40x20 30K gallon rectangle pool with a WFDS-4 (Whisperflo 2 speed 1 hp pump), 2 Intellibrite LED's, possible heater/solar heat down the road. My question is which system would work better with my setup the Pool Pilot Digital or the Easytouch with Intelliclor?
I would like to be able to program times for the pump to turn on/off and program times for the pump to run in high and low speeds. From my readings I've learning that the AutoPilot can only turn a 2 speed pump on/off high speed and that unless there is an additional timer put in to control power to the AutoPilot then basically the pump will run 24 hours a day.
Will the Easytouch setup allow my to program my pump to be off certain hours and also program when it is in high or low speed?
Thanks.
Thanks.
