Thread: inground or aboveground difference robots
    Sep 2009
    tennessee
    17
    what is real difference between ig & ag robots? looking for best value possible, maybe "the pool cleaner" ??? thanks.
    15k, ig ,vinyle ,kitbuilt, 1hp hayward, 24 hayward sand, 2-intex swg`s, manual cleaning, leslies k2006 test kit,14x28, fiberglass steps
    Re: inground or aboveground difference robots
    Most above ground robots will only work in a pool with a completely flat bottom and vertical sides. The in ground robots are able to traverse slopes. The in ground robots are also usually designed for larger pools than the average above ground robot.
    Sep 2009
    tennessee
    17
    thanks for the reply my inground has aflat bottom with a 2ft 45 degree slope up to bottom of pool walls so actual flat is 10x24 I like the idea of robots because of extra filtering plus not interfering with skimmer since i didn`t plumb in extra suction line. have also heard good things about ''the pool cleaner'' any advice??? thanks
    There are so many choices in pool cleaners, none of them perfect. It is difficult to recommend anything in particular. The Pool Cleaner has had a number of positive comments.
