Thread: Zero pressure on filter??
    Apr 2010
    Sunny Phoenix AZ
    74
    Hi guys, I just backwashed my system as usual, and I can't get the pressure on the filter to rise above zero. If I partially close the return valve the pressure gauge rises, so I'm reasonably sure the gauge isn't to blame. Normally it sits around 15-18psi.
    The system is flowing water; the pool vac is operating although it seems as if the pressure is actually lower than usual.
    What am I missing here?
    28,000 gallons / Plaster / Hayward 30" Sand Filter / PoolCleaner 4x / PoolSkim / Hayward RS1500 / CircuPool RJ60
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Zero pressure on filter??
    Did you put enough DE back in the system after the backwash?
    Apr 2010
    Sunny Phoenix AZ
    74
    Nevermind...solved it. Impeller had a wad of **** in it...thanks
    Feb 2011
    La Quinta, CA
    21
    15to 18 lbs is normal reading.....anything higher than 25 indicates your filters are getting very dirty. A zero reading means the filter system is not working. Time for new filters
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Quote Originally Posted by Rockman59
    Or like the OP mentioned, it could have just been a clogged impeller or even a bad gauge. I'd hate to see someone replace their filter just because the gauge reads zero, before trouble shooting the issue first.
