Results 1 to 9 of 9
Thread: How high can the water get on top of winter cover?
    We have had a few thaws in the last month and this weekend it is pouring rain. The top of the winter cover looks like an ice rink and I went out and noticed that in addition to the ice, there is water almost up to the level of our stone coping. Is there any concerns about how high the water level on top of the cover is? Additionally I noticed an area along the side of the pool where the cover has pulled out from the liner snap in. It is about 1 foot long. Do I have to be concerned about snow/water getting into the actual pool? Thanks.
    16 X 32 Vinyl. Hayward aqua rite salt system, T -15 cell. Hayward H250 gas heater, Hayward 1HP superpump.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: How high can the water get on top of winter cover?
    You should be pumping the water off the top of the cover if it's a solid cover. If it's mesh, your cover is sinking into the pool.
    It isn't a solid cover or a mesh. Its kinda like a tarp. It doesn't allow the top water to go through, but it isn't rigid.
    Dec 2009
    Central Massachusetts
    2,690
    Just an FYI. If the cover isn't a mesh cover its known as a solid cover. Solid as in water won't pass thru. Not solid as in rigid.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    South Central NJ
    3,192
    A water bag tarp cover should have a little bit of water to keep it from luffing in the wind. The rest needs to be pumped off or the weight of the water on top will pull the edges into the pool as more water collects on top.
    A properly done cover will have no less than two feet of overlap when first set. The only exception is at the dive stand where it is often not available.
    Scott
    Owner of - PoolGuyNJ LLC
    Ottawa, ON, Canada
    153
    Quote Originally Posted by PoolGuyNJ
    Scott
    And in my case, that **** cover either wants to fly away until there's enough water on it or there's some air in one spot that once in rains a lot it creates a fold that sinks in the pool and wants to pull the remainder of the cover with it especially in the areas where the water bags were chewed by squirrels or some animals and have drained almost completely.
    I'm hoping life will be easier once I move to a mesh type safety cover..
    19.5k gallons in ground, P4 panel with turbocell SWG, 1hp Hayward superpump II, sand filter, Heater low nox 250k btu heater, solar cover on rocky roller
    Quote Originally Posted by bk406
    Thanks for the info.
    Anyhow, it got cold again, with about 4 inches of snow. So the water is frozen again and it's covered in snow. For future reference, should I go buy a pump and drain the cover any time it gets mild over the winter, or should I just wait until spring when it melts and pump it off then. Our pool company that does our opening and closings didn't tell us to do anything.
    It is always good to have a cover pump regardless, so I would go ahead and get one.
    As for draining water, you don't normally need to do so once freezing weather sets in. However, if the water gets that deep on top of the cover it is a good idea to pump it off when you have a chance. I'm not sure where you live. Around where I am, it would be extraordinarily rare to get that much water on top of the cover.
    One final thing to watch out for. If the cover developed a hole, water from the pool can flow out on top of the cover, creating a situation much like what you describe. If there is a significant hole, you don't want to pump the cover off, as that will simply result in pumping all the water out of the pool.
    Thanks for the info so far. I live in Ontario Canada, so we get freezing weather in the winter. Anyhow, the cover was pretty much covered in snow most of the winter. We had a few mild days in which some of it melted and then turned to ice upon colder temps returning. Over the past weekend it became quite mild with prolonged rain. Then it turned cold again with about 8 inches of snow. So even if I had a pump, I couldn't drain anything since it's now frozen again.
