Thread: Salt Testing?
    Apr 2009
    Lancaster, pa
    71
    Salt Testing?
    I am going to be installing a SWG on my AGP this spring..was just wondering what method is best for testing salt content in pool?
    Test strips seem to be easy, but are they reliable?
    Thanks for any info!!
    Curt
    24' AGP (13,600 gal)
    Sand Filter with 1.5hp pump
    Lancaster, PA
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Salt Testing?
    Quote Originally Posted by chdolfnz
    Curt
    Fresh Aquacheck salt specific test strips are accurate to +/-200ppm, which is more than enough (tfteskits.net carries them as well as the taylor drop based kit)
    22,553
    Re: Salt Testing?
    I have the Taylor K-1766 salt test kit and it does a great job of testing the salt. You do have to be careful to watch the endpoint closely. According to a lot of people on here the strips do a great job too.
    JoshU's Avatar
    New Orleans, LA
    543
    Re: Salt Testing?
    Aquachek makes the best salt strips around.
    Depending on which brand system you have you may get a good accurate salt reading from it.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Apr 2009
    Lancaster, pa
    71
    Re: Salt Testing?
    Thanks everyone!!! I figured the strips would be fine, so that is what I will use.
    Curt
    Lancaster, PA
