Thread: Frozen water in return
    My pool is uncovered, had been properly winterized and we finally have thawed after about 3 solid months of frozen. I noticed that one of the rubber plugs had fallen out (sitting on the bottom) and the water level has risen above the return. My guess is the water got in to the return at some point and it froze. Any issues with this? It is a gunnite people and I swear the wall where the return is looks like it has bulged outward. Is this possible in 8 inches of concrete?
    Will be getting ready to open around April 1 before the higher temps start the pea soup.
    24,000 gal free form with slide feature
    3.5ft to 5.5ft Sport Pool
    Midnight Blue Diamond Brite
    Intellichlor IC-40
    Intelliflow VS-3050
    Easy Touch 4
    Clean and Clear Cartridge
    22,542
    Re: Frozen water in return
    It is possible but not very probable that the wall bulged out. A pressure test of the piping will tell you if the freezing burst anything. It's possible that everything's fine.
