- Jun 6, 2007
- 33
- Plaster
- Hayward Aqua Rite (T-9)
I just replaced a 12 year old Speck 2 speed 1 1/2 hp pump with a Whisperflow 2 speed 2 hp pump, and it seems the Speck pump was better. Here are my observations since the pump replacement:
1. Priming takes a lot longer.
2. Filter pressure with new, clean 100 sq ft cartridge filter is now about 2 psi, with Speck pump it was about 8 psi
3. Water movement around the pool seem to be dimished.
4. Pump loses prime afer being off for a while.
I replaced the Speck pump because it was stating to make noise, and I was hoping for something more efficient. All of my observations are based on the Speck pump in it's deteriorated condition, it was still performing well.
Do I need to get the pool guy out here? What does he need to check for? Can I assume my system had no leaks proir to pump replacement, and any leaks are a result of the work I had done?
Thanks in advance for your help.
DerrikMo
DerrikMo
