Thread: Dichlor to Raise CYA?
    Jul 2009
    Long Island, NY
    267
    I will soon be into my 3rd season with my new pool and have used the BBB method from the beginning. Up until now, I have only used my SWG and bleach for chlorinating and used 100% CYA granules for adding stabilizer. I'm ssuming that I will need to raise my CYA level after I open this spring due to vacuuming to waste. What are your thoughts on using dichlor to raise the FC to shock level and gaining the benefit of some "free" CYA? Or, is it better to continue using just bleach and 100% CYA granules?
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Dichlor to Raise CYA?
    It's an excellent idea. That's what I generally do.
    Jul 2009
    Long Island, NY
    267
    Thanks John. Are there any undesirable side effects of using dichlor?
    Dec 2009
    Central Massachusetts
    2,690
    I do the same thing with no issues. Just watch the CYA levels. For every 10 ppm FC you add using dichlor, you add 9 ppm CYA. So just keep track of it.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Ohio
    217
    I also do the same. The only side effect I find is my ph falls quickly(daily)You will need to keep a eye on the ph if you are set up for bleach.
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
