Thread: Salt Water Chlorine Conversion
    I'm looking to replace my pool pump and filter plus convert to a SWG system. Currently, I have a Hayward Micro Clear DE-4800 Pump/Filter and the Hydramax II Inground Pool Pump (which is making a horrible grinding noise while it's running). I have the Polaris 380 with a boost pump as well.
    I don't believe I need to replace everything above, however, I'm thinking at a minimum I would like to replace the pump and convert to a SWG system. Anyone have some recommendations?
    Appreciate any comments. Thanks!
    South Central NJ
    3,192
    Re: Salt Water Chlorine Conversion
    In order to give you a proper list, we would need to know more.
    What size is the pool?
    What size is the plumbing?
    Is there a heater?
    How old is the pool?
    Liner, Concrete, or fiberglass?
    Attached spa?
    Owner of - PoolGuyNJ LLC
    Quote Originally Posted by PoolGuyNJ
    Is there a heater?
    Attached spa?
    The concrete pool size is 38' x 17' according to the pool permit drafted in 1972. It's a 27,500 gallon pool with no heater although there is a gas valve there as if they had one at one time. There is no spa. There is 2" plumbing already going from pump to filter.
    Thanks very much.
    South Central NJ
    3,192
    A Pentair VS-SVRS pump and an Intellichlor IC-40 will be fine for your needs.
    Scott
    Scott
    Scott,
    Thanks very much. I'll check it out.
