Thread: SWG and Solar Heater Question
    Mar 2011
    Port St. Lucie, Florida
    12
    I am currently in the process of having my pool resurfaced, and I am planning to install a SWG and solar panels in my backyard. I have seen some people having issues with their SWG destroying their heaters, I am wondering if this will happen to my solar panels if I use a SWG that I will install the same time as my solar panels.
    In-Ground Fiberglass 3,500 gallon pool
    Jacuzzi CFR Cartridge Filter
    1.0 HP A.O. Smith Pump
    Mar 2011
    12
    Topics merged. Please don't ask the same question in more than one place. JasonLion
    South Central NJ
    3,192
    Re: SWG and Solar Heater Question
    The cell must be the last thing in line before going to the returns. Those that had problems were due to installation before the heat source.
    Scott
    Owner of - PoolGuyNJ LLC
    Oct 2010
    Georgia
    317
    The issue with the heaters and salt was also with earlier copper heat exchangers.
    Newer heaters have Culpro-nickel or Titanium heat exchangers and are much more resistant to salt and poor water chemistry than early models.
    Solar panels don't use metal heat exchangers so there is no problem with Salt systems and Solar heating.
    Enjoy your new pool upgrades
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    It is very unusual for a SWG to cause any problems for a heater. That would normally only happen if the SWG was installed incorrectly.
    There are no issues between a SWG and solar panels.
    Even a straight copper heat exchanger will not have problems with the salt levels used by most SWGs. Copper starts having problems well above 6000 ppm of salt, while most SWGs these days use levels around 3000.
