Results 1 to 10 of 10
Thread: Max Flo 2 pump takes 10 minutes to prime
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Does anyone know why this might be happening?
    The pump room is not that far from the pool. maybe 20ft. When I cut the main drain off to vacuum the pump sucks air so maybe this could be one reason. Also before the grass grew there was a lot of dirt in the pool so I think overtime the dirt might have worn down the impeller and this could be another reason maybe? I've heard of pools by the beach having that same problem.
    Jan 2011
    153
    Re: Max Flo 2 pump takes 10 minutes to prime
    Sounds like either a bad pump seal or your unions have a small suction leak... My bet it's the pump seal..
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Quote Originally Posted by Keven
    Thanks I'll check on the pump seal. the valves are inside pump house so doubt its them. they look good. sun usually makes them brittle if they are outside and then they suck air. also seen plumbing crack due to sun damage.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Besides an air leak, a clogged impeller can also increase the time it takes to prime a pump. But if you are losing prime between run times, then it is definitely an air leak. A pump should not normally lose prime unless air is entering the system somewhere.
    Mark
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Quote Originally Posted by mas985
    it actually only loses prime when I open the strainer basket to clean it. no matter if I fill it with water it still takes 10 minutes to prime.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Then it could be a partially clogged impeller.
    Mark
    Jan 2011
    153
    If it's a clogged impeller the pressure on the filter would run much lower..
    South Central NJ
    3,192
    Aquatica, what pump, what filter(s), flooded suction or elevated?, etc...
    Scott
    Owner of - PoolGuyNJ LLC
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Quote Originally Posted by PoolGuyNJ
    Scott
    max flo 2. ec65
    pump house is only very slightly elevated compared to pool.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    this is the pool. pump house is right in back of that hammock..
