Thread: Initial AGP Treatment
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    What a great site, so much info and help available!!
    In the process of putting all the peices together for a spring AGP and deck install, I'm trying to track down some info regarding the initial treatment of water into the pool, in my noobness I'm unsure if the chemical balancing of the very first start up is the same as pring opening of an existing pool.
    I'm planning on using the BBB method.
    I've searched thru the boards but most of the info I'm finding pertains to opening an existing pool and generally pertains to people with at least 1 season under their belts, if anyone could direct me to some info on initial start up with the BBB method I'd appreciate it.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: Initial AGP Treatment
    Cramar,
    I would suggest you read through Pool School. The link is in the upper right hand corner of the forum. It should tell you everything you need to know about taking care of a pool.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    dmanb2b's Avatar
    Apr 2009
    NY
    3,729
    Cramar, welcome to TFP
    Get a TF100 and a Taylor speedstir (Tftestkits.net) , then test your fill water PH, TA and CH. We'll be able to assist you from there.
    When you initially fill the pool, you'll need a few bottles of bleach or liquid chlorine to start and some CYA (aka conditioner/stabilizer) to get your CYA level to around 30ppm to start. From there you'll just need to make sure you have an FC reading of 3-4ppm every day. Retest CYA after 7days and we'll fine tune your chemistry from there
    The first step is to get water test results for your initial fill water. Depending on what those readings are there are quite a number of different things you might need to do.
    You will want to have some bleach and cyanuric acid on hand. There are several other things you might need, depending on what your test results show.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Thanks for the great responses, I bookmarked that test kit.
    I'll order that and do a test run on the house water and get a plan of attack together, once the pool is up I'll get some samples and go from there. If I need help I'll post the levels here.
    Thanks for the suggestions.
