Results 1 to 7 of 7
Thread: Anyone using LMI pump for chlorine dosing?
    Hello,
    I'm in the process of assembling my pool system, and and going to use the BBB method, but wanted a continuous dosing of the bleech as to consistantly maintain the FC level rather than have the swings from too much to too little, I know I will still need to adjust for weather and bather load, but figure it will still be minimal.
    Anyways, I have aquired an LMI P121-158 dosing pump for cheap, but it didn't come with the foot valve or the 4FV (priming valve), and am wondering if I really need these?
    Does anyone have any examples of how these are installed?, pics?
    Any help is greatly appriciated.
    24' round x 54" Tahitian (Sharkline), 1.5HP Sta-rite Pump, 22" 250lb. sand filter with Zeo-best media, Hayward H250FDN heater, Del Clear Ozonator, SWG or Rola-Chem feeder, not sure?, Trident Automatic Pool Cleaner, 100Watt Nightlighter, Underwater light show and fountain, 2" Hard Plumbed.
    Wishin Isa Swimmin!
    22,553
    Re: Anyone using LMI pump for chlorine dosing?
    given your suction head from the container to the pump you may not need the foot valve. Keep in mind that those diaphragm pumps can be a bit of a pain to prime. Once primed it should be fine. You can always buy a foot valve later if you find you need it.
    Thanks for the information, I'm considering buying a Rola-Chem feeder now since I've heard that diapham pumps don't like liquid chlorine all that much.
    Wishin Isa Swimmin!
    Mar 2011
    441
    I'd give you an LMI pump for free, but I woudlnt be doing you a favor.
    I prefer stenner pumps to rolachem. Rolachem seem incredibly cheaply made.
    20X40 30,000 gallon gunite pool
    Stenner pumps are alot more $$$ than the Rola-chem pumps, which is the reason I chose the Rola-chem, I haven't really heard anything bad about them.
    It sucks that I already bought that LMI pump, but I guess I'll just post it on kijiji or ebay or something, use it as a paper weight ha! ha!
    Wishin Isa Swimmin!
    Guest
    Love my Rola Chem. I use it with a fifteen gallon Carboy!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have been using an LMI pump since last year for Chlorine, so far so good, I have only had issues with loosing prime a couple of times this winter with the limited circulation going on and pump being turned down to very low levels.
    see my set up here new-metering-pump-project-t22358.html?hilit=lmi%20pump
    Ike
