Thread: Twisted pair 20awg??
    Feb 2010
    Blessing, Tx (South of Houston)
    82
    Im on the final few steps of my plumbing renovation and new equipment install, just getting ready to install my GLC solar controller and i ran into a problem. The book says to use "twisted pair 20 awg" wire to install the sensors, but what exactly is this? I looked around homedepot.com and could find twisted pair 18-2 (its speaker wire) but not 20 awg.
    Anybody know what i should be using to connect these?
    Intex 18' AGP - Intex SWG - 19 inch Sand Dollar Sand Filter - 1HP Pentair Dynamo Pump - 4X20 Solar Panel - Goldline Solar Controller.
    Dec 2009
    Central Massachusetts
    2,690
    Re: Twisted pair 20awg??
    It's just thermostat wire. It's usually that brown stuff that comes on roles.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Feb 2010
    82
    Awesome thanks, why couldnt they just say that and make it easy!
    Sep 2008
    The Woodlands, Texas, USA
    243
    Home Depot sells a GE Category 3 wire which would be more than good enough. Twisted thermostat wire also very similar. CAT 5 wire would work also but 23 g may be a bit small for your terminals. I prefer solid copper wire for permanent runs and stranded wire for jumper wires or cable subject to exterior of cabinet bending and flexing.
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
    22,550
    Twisted pair 18 awg will work fine. I prefer shielded twisted pair on all sensor wiring, but it's a little harder to find.
    Feb 2010
    82
    Quote Originally Posted by learthur
    Cat5 cable is a good idea I've got a couple hundred feet in the closet!
