Results 1 to 19 of 19
Thread: Pool surface questions
    Hi,
    I am researching options for a new pool build in Scottsdale, Az. I know the aggregates are the way to go for longevity. (especially in Pebble tec's backyard) But (ya knew this was coming) I hate the textured feel. I really want a smooth surface. I also don't love the artificial natural look. I have a pool, I don't think I can fool people into thinking there is a natural pond in my backyard
    I'm not enamored with pebble sheen.
    we have considered Beadcrete for the look, but I'm uncertain about the feel, and have heard that poor applications can result in broken glass beads which are hard to remedy. (are there other glass bead options?)
    The quartz products seem to have problems with keeping true color. I'm not sure about the longevity. I thought I read were the initial claims of better wear with the added quartz isn't holding up due to the other polymer in the matrix being the rate liming factor.
    Please give me any suggestion you have, and let me know if any (or all) of my understandings of these products are off base.
    thanks
    16 K gal pool & spa, concrete (pebblefina), Jandy aquapure SWG, Jandy pda-PS3, PV3 infloor cleaning. built 2011, scottsdale,az
    Guest
    Re: Pool surface questions
    What about Pebble Fina?
    South Central NJ
    3,192
    Sheen is smoother than fina..
    There are polished plasters like Hydrazzo and Durazzo but they are basically plaster. They are smooth but don't last any longer than plain plaster, at least I haven't seen them last longer.
    The quartz finishes do last somewhat longer than the regular plasters due to the increased quarts aggregate taking some of the exposure area away from the cement in the mix. Also pretty smooth.
    I never trust anything glass near a pool, let alone in a pool.
    I do trust just-a-pb.
    Scott
    Owner of - PoolGuyNJ LLC
    If you want smooth and a natural look its hard to beat a traditional plaster finish. Although its taken a bad beat because it has been around since the beginning of pools, we have many pools that are over 20 years old with the original plaster finish. The average life in our area is easily 15 to 20 years for residential pools. We also have quite a few pools with diamond brite that are in the 12- 18 year range in very good shape. You can do a quartz finish without the acid wash and still have a smooth finish if your not anxious for the exposed aggregate look.
    Guest
    Sheen is the smoothest of the exposed aggregate finishes, but Fina is the smoothest of the three offerings from PebbleTec. Fina is more like a traditional plaster finish, but with quartz in place of the typical limestone in today's plaster.
    Fina will buy you longer life over plaster, and will look most like plaster, but Sheen (in my opinion) will be the longest lasting. The smaller rocks fuse together tighter and provide a much stronger finished product.
    Feb 2011
    Petaluma, Ca
    665
    Im going through this same process. I am concerned that pebble tech will be too rough. I've read here that it will last the longest, longer that pebble sheen. I think the "tech" looks better but will your feet get sore.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Guest
    The larger stones end to pack a little "looser" and leave more plaster exposure. The smaller stones pack tighter, leaving less plaster exposed. Plaster is the weak link in the product, so more rock equates to longer life.
    Both are durable, but I believe (after 15 years in the industry) that the smaller stone (Sheen, in this case) will provide the most durable finish. I have it in my pool, and that is what I would put in again. Both have more texture than plaster, but they are rounded, smooth stones, and it is comfortable to walk on. Both will abrade you if you hit it hard enough, as I know all too well from experience!
    Guest
    Quote Originally Posted by PoolGuyNJ
    Scott this is incorrect, Fina has all the dust and chips from pebble products and is more like a plaster product but last longer.
    Look here...
    http://www.pebbletec.com/pebble_fina_swatch.aspx
    We used WetEdge Primera in my pool which is an aggregate finish but polished smooth. We are very pleased with the surface so far.
    http://www.wetedgetechnologies.com/p..._signature.php
    20'x34' gunite pool, 7' raised spa, Wet Edge Primera, VS3050 pump, 2x whisperflo pump for water features and in-floor cleaner, CC520 Cartridge filter, Pentair 400k btu heater, Intellichlor IC40, Paramount PV3, Easytouch8
    Quote Originally Posted by salp
    Look here...
    I'm hearing different things about Pebblefina. I think it is equivalent to the quartz products but use stone as the pozzolans into the cement mixture. Any reason to think it would last any long than the other one, besides the reputation of the manufacturer?
    Guest
    It is very similar to some quartz products. The quantity of the quartz is what makes creates the longevity and durability, and more is better than less in this case. The strength of the company and the requirements of the applicator of P-Tec products also comes in to play.
    Any quartz product will be stronger than today plaster (cement and limestone). How much stronger depends on the mix.
    Quote Originally Posted by simicrintz
    so in your opinion is there a better product than fina?
    Guest
    Not in quartz. I still think Sheen is the most durable, but it doesn't sound like you are leaning towards exposed rock.
    What's the delta between the quartz you're looking at and the Fina?
    I was not looking at a specific quartz product. I was just looking for the best smooth option out there. I'm willing to entertain any smooth surface that will last (and not cost a fortune like tile). pebblefina seems to have taken the lead.
    There are lots of trade-offs. Hydrazzo is the smoothest finish, but you pay a whole lot for it and it isn't a great deal more durable than plain plaster.
    I don't need the smoothest, just a mostly smooth surface that will be durable and last. (deep blue color would be nice)
    Guest
    Get the Fina and be done You'll be happy you did
    Guest
    Here's a good YouTube video on PebbleTec: http://www.youtube.com/watch?v=F1M8DOeY0I0
    Hope it helps
    I'll probably to the pebblefina, thanks.
