Thread: small crack in skimmer
    Sep 2009
    tennessee
    17
    this year as I was closing pool found hairline crack around 1 1/2 outlet on flat part of skimmer bottom am thinking of using silicone with 1 1/2 adaptor to seal is this best solution short of replace skimmer? thanks for your help anxious to open.
    15k, ig ,vinyle ,kitbuilt, 1hp hayward, 24 hayward sand, 2-intex swg`s, manual cleaning, leslies k2006 test kit,14x28, fiberglass steps
    Dec 2009
    Central Massachusetts
    2,690
    Re: small crack in skimmer
    Why dont you just use some epoxy? It will seal and hold a lot better than silicone.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    JoshU's Avatar
    New Orleans, LA
    543
    Replacing a skimmer is a big job. As BK said I would try to epoxy route.
    Pool Putty is good stuff: http://www.google.com/search?aq=f&sourc ... pool+putty
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
