Thread: Concrete and Freeze
    Jan 2011
    Riverside, CA
    352
    Concrete and Freeze
    We poured the concrete decking on Wednesday (2/23) it is supposed to just hit freezing temperatures tonight (Saturday Night>Sunday Morning). The forecast is:
    1AM - 34 deg - Wind 1 mph
    4AM - 32 deg - Wind 2 mph
    7AM - 31 deg - Wind 4 mph
    10AM - 45 deg - Wind 0 mph
    This looks like the only time it will get below zero in the next 7-10 days.
    Should I be concerned? Is there anything I can/should do? I do have some big sheets of plastic tarping that I can use if necessary.
    Material is Stamped (wet release) and Colored if that makes any difference. I'll update my build thread if I get time tonight or tomorrow
    Thanks
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
    South Central NJ
    3,192
    Re: Concrete and Freeze
    If the mason was worried, he would have added a little extra calcium to help it along. FWIW, hydration generates a little heat but that is gone now. In any event, I wouldn't think there is enough moisture left to cause an issue.
    Scott
    Owner of - PoolGuyNJ LLC
