Thread: solar cover
    solar cover
    hi
    would layering 2 solar covers help keep more heat in?
    thanks
    gary
    thanks
    gary
    24ft x 54" aquasphere mission agp, cartridge filter, 1.5 hp hayward, TF-100, BBB method, pool install July 2010
    22,548
    Re: solar cover
    Maybe, but it probably wouldn't be worth the cost or extra handling of the second blanket.
    Re: solar cover
    The great majority of the "keeping heat in" comes from stopping evaporation. Any solar cover will do that. There are some small additional gains to be made by increasing the R-value by using something thicker or specially insulated, but the great majority of the savings is from simply having a cover at all.
    Re: solar cover
    So would it be reasonable to use a winter cover instead of purchasing an additional solar cover?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: solar cover
    Quote Originally Posted by Candi
    Probably not. Solar covers are fairly cheap until you get to larger pools. The inconvenience of moving a winter cover, the fact that it lets no sunlight into the water and the shortened life of the winter cover would probably negate any savings. Anchoring a winter cover would be an issue to, since the solar cover is sized to float on the water with no overlap so the wind won't lift it.
    Re: solar cover
    Quote Originally Posted by JohnT
    Ok, makes sense. In that case, would it be OK to use a solar cover that is smaller than your pool size? We are getting a 18x34, but I have found a few good deals on solar covers for 15x30. (or maybe it was a 16x32, not sure)
