Thread: (Q) Muriatic acid alternative
    Sep 2010
    Roatan - Bay Islands
    35
    For as common as it seems, I am having hard time finding acid muriatic at my local supermarket or anywhere where I live. It may be weeks before they will stock it up again.
    Is there a common product that I can use as an alternative ?
    I just found out that, in my BBB method, using common bleach (12%) is causing my PH to constantly rise, thus I need to use a fair amount of acid on almost a daily basis to keep my PH in check.
    P_
    _________________
    10,000 glns bean shaped inground plaster pool - Pentair SD60 sand filter - Pentair 3/4 HP pump
    Mar 2007
    San Rafael, CA USA
    12,085
    Re: (Q) Muriatic acid alternative
    For less of an effect on pH, keep your Total Alkalinity (TA) lower. You might need to raise your pH target and/or CH to compensate for the saturation index. It could also be that the chlorinating liquid that you are using is high in pH. Good quality 12.5% chlorinating liquid has a pH of 12.5; more typical ones have a pH of 12.8; ones with a pH of 13 or higher would have a noticeable rise in pH that even a lower TA won't help prevent.
    As for acid, you can use dry acid (sodium bisulfate), but check hardware stores as they usually have Muriatic Acid -- it's used for cleaning outdoor pavement, among other things.
    Aug 2009
    Largo, FL
    19
    Quote Originally Posted by chem geek
    I've found this at Home Depot, tucked way back in the garden section. You may have to clear off a layer of dust but they may have it.
    24' AG, 2 hp 2sp brand new (Aug 09) cartridge filter & pump.
    Loads of pool toys and a very impatient little girl who wants that pool ready yesterday!. :)
    Sep 2008
    The Woodlands, Texas, USA
    243
    Adding Borax to your pool may help buffer pH changes also.... although there will be an immediate pH rise when you first add it.
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
