Thread: Heat Siphon (analog or digital)
    Sep 2007
    New Jersey
    Im having a pool installed and im going to use a Goldline Aqualogic Controller. I want to purchase a 3.25/80,000btu Heat Siphon heat pump. Not sure if I need the digital model to work with the Aqualogic or can I go cheaper with the analog?
    14x32 fiberglass
    What do you want to control. The heat siphon already has a flow switch in it that will only let it run when the water is flowing. I have my main pump on a timer to come on at 10:00 am and off in the evening 1t 8:00pm this way the heat pump will only run during the warmer part of the day.
    No, you don't need the digital model. Digital heaters tend to have a slightly better control panel and slightly better temperature regulations, but really the differences are small.
