Thread: Need PART: LAARS heater controller/ignitor board
    Sep 2008
    The Woodlands, Texas, USA
    243
    [attachment=0:1z4t1ifw]FENWAL.jpg[/attachment:1z4t1ifw]Please see attached photo.
    I have a LAARS which stopped igniting. I did troubleshooting and determined the ignitor comes on but the gas valve didn't. Applying 24vAC to gas valve did make it light up. Testing the control board indicates no AC voltage on the VAL (valve) terminal, therefore I think the problem is the control board.
    Only found a couple places on the internet with FENWAL E0157800 replacements using either a FENWAL R0325200 or a FENWAL R0408100 for $200-300! These $40 boards can not be this expensive.
    Anyone know where to buy one of these cheaper?
    Lee
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
    Oct 2010
    Georgia
    317
    Re: Need PART: LAARS heater controller/ignitor board
    Here is one on Craigslist near Houston:
    http://houston.craigslist.org/for/2173864253.html
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Sep 2008
    243
    Thanks everyone for your input. Was surprised by the availability on Craigslist.
    I discovered Fenwal no longer makes this model# however they make a compatible model.
    I was able to locate the compatible unit from www.patriot-supply.com for $117.
    Still overpriced, but better.
    The only difference is the unit has a 20 second ignitor warmup instead of a 6 second warm up. So not as fast starting up but should work fine.
    I have purchased a lot of HVAC equipment wholesale so I have an idea how much markup is in this stuff.
    This particular model is a pretty simple controller compared to others also.
    I will post again if this doesn't work for some reason. Nice temps in Houston now. Time to warm the pool!
    Sep 2008
    243
    New Fenwal working great. Nice improvement. New model has an error light and convenient terminals to check milliamperes current from flame sensor. Otherwise works the same.
