Thread: Pump Advice - Pool/Waterfeature
    I have been a lurker for sometime. I am currently in the middle of a OB/DIY build. I am indebted to this forum and another forum for the learned knowledge to build a pool. I am at the point that I will need to purchase a pump(s) and would like some advice.
    All plumbing is 2" except Polaris. Main drain and 2 skimmers each home run to pad. 6-7 returns split into 2 home runs. No spa. Water feature is 2 fountains with spillover into pool and 1 bubbler in sunshelf. For water feature I plumbed wall drains to pad with 1 run to fountain and 1 run to bubbler.
    Option 1: (1) VS3050 used for pool and water feature with valving (could add extra pump later)
    Option 2: (1) VS3050 for pool, 1hp single speed for water feature
    Option 3: (1) 2 speed for pool, VS for water feature
    I am in Texas so electricity is about .11/kwh
    Question: Opinions? Comment?
    Sorry for the long post. And thanks in advance.
    22k gal, gunite, Pebblesheen, fountain/waterfall, no spa, Quad 100DE, Easytouch4, Pentair VS3050, Polaris 280, TFP-100 kit, Stenner pump
    Re: Pump Advice - Pool/Waterfeature
    I would go with option 1, a single VS3050 and a Pentair automation system. Using a same brand automation system will allow you to program flow rates for each mode and to switch between modes very easily. You will also be able to tune the flow rates to get exactly the amount of fountain action you want. The caveat is that this only works if the total flow required by the fountain isn't too large. For very high fountain/spillover flow rates it is better to have a separate pump that does not go through the filter. Generally you only see those "too large" flow rates with waterfalls or a negative edge, most fountains will be fine.
    If you do go with two pumps, I would suggest option 3. There is no point in getting a VS3050 just for the pool when your electric rates are that low. Meanwhile, being able to dial in the ideal flow rate for the fountain is still very handy. One advantage of option 3 is that you wouldn't really need an automation system, manual controls will be good enough (though automation is better).
    South Central NJ
    3,192
    VS-SVRS has built in timers, up to 8 speeds and 7 events and it's a safer pump.
    Scott
    Owner of - PoolGuyNJ LLC
    Thanks for the advice.
    Option 1 was my original intent and I puposely paid a little extra in materials and time to plumb the extra wall drains in case I had to add another pump. I should also save on electricity during the winter when the freeze protection is on without the second pump.
