Thread: Constant depth pool?
    Sep 2007
    Madisonville, LA
    My wife and I are in the process of designing our pool and are considering a constant depth of about 4'6". Our kids are gone and we don't want a diving board. We just want to float and relax. I would think this would lower the cost of the pool. I know from experience that a big aquarium is easier to maintain than a small one. Does this hold true in the pool world?
    10200 gal 12x24 IG vinyl, Dual Main Drains, Sta Rite System 3 cartridge filter, 1.5 HP pump, Zodiac LM3 SWCG, Letro Platinum w/booster, Colorlogic, Spraydeck, Deck jets, Oasis 36" Arch Waterfall, custom built BBQ island
    Having a uniform depth will help a little, but it won't be dramatic. I like to have an area that is a bit deeper to do exersizes in, but to each their own.
    Depends by bigger do you mean deeper (more gallons bigger) or size sqft 20x40 compared to 15x30.
    If deeper, having a pool 4.5 ft deep all around is not much more maintenance if you went with 2/3rds of the pool 4.5ft and sloped to 6.6 ft.
    In a 20x40 pool (considered pretty large for a home pool)that would roughly be 27,000gls versus 29,500gals. Scrubbing the walls in the deep end might add 10% more effort
    But using the big aquarium, small aquarium analogy a 15x30 pool at 4.5ft is 15,220 gals vs a 20x40 4.5ft 27,000 gals. This is a huge difference in maintenance and effort about 33-40% more effort (just a guess).
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
    Mar 2007
    Ontario, Canada
    If you are going with a vinyl lined pool I don't think its going to save you that much on initial costs, just maybe a little in materials and a little more digging involved. As for gunite, I am not sure. You might want to consider that even though you don't have kids, you won't be able to dive in the pool at all. I myself couldn't imagine not being able to take a nice dive off the diving rock into the pool. If you are going to float around anyways it really doesn't matter how deep it is does it? And remember that you will always have to remind guests that there is no deep end, which is minor I guess. The positives are that you can play water volleyball without having to tread water and it won't take long to heat your pool which is a cost savings.
