Thread: Atlanta Area PB recomendations
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    I'd posted a question about what to look out for when buying a house with a pool. http://www.troublefreepool.com/advic...ls-t28644.html I'd gotten a lot of good advice. One of the suggestion is hire someone to inspect the pool. I'm in Lilburn, GA, just east of Atlanta proper. Anyone have good experience with PB out this way that they would recommend to do a pool inspection?
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Re: Atlanta Area PB recomendations
    Have you bought a home yet or still looking? What kind of pool does the home your looking at have (vinyl, fiberglass, concrete)?
    In North Atlanta, my choice would be Atlas Pools on PIB at I-285 or Blue Haven Pools in Johns Creek. If they are to busy with pool openings, call Andy's Pool Service and specifically ask for Bill to see if he could do a detailed inspection. PM me if you want or need numbers. Let them know what you are doing and that you need an inspection before purchase and an opinion of the estimate of the life of the equipment and pool surface (how long on the liner, how long before re-plaster). This way you know what might be needed later and what is working now and what the sellers should fix before purchase. Just as a 20 year old roof should be replaced by the seller before closing, a 10 year old vinyl pool liner should be replaced by the seller before closing in my opinion.
    The best thing we every did was require the seller to buy a 2 year Home Warranty from AHS to include two years on the pool before we bought our home. The DE Filter died as well as both pumps and we had an oven problem, HVAC heater issue, and the three year old hot water heater died, none of which were Red Flags at the time of the home inspection. Our refrigerator we moved to the house died and was still covered. Best thing we ever asked for above the usual in a home closing. AHS had a $50 deductible per call (this was 10 years ago), so if you need to call them, make sure all the pool equipment is checked after opening the pool because we got a new filter, and two new pumps for one $50 deductible.
    Pool #1 IG 24k Diamond Brite plaster with spill-over spa. Jandy Aqua Link RS One Touch with built into pool floor cleaner. Jacuzzi Magnum pump/basket feeding Hayward top mount Zeosand filter. Jacuzzi Magnum pump/basket for Spa Jets. Heat Siphon pool heat pump. Dolphin Robotic pool cleaner.
    Pool #2 IG 35K 20X40 Vinyl. Hayward top mount Zeosand filter with Pentair 3 HP IntelliFlo VS+SVRS. Chemical Free pool using Water Doctor Copper Ion Generator, PoolSkim, Polaris 9300 Sport robotic pool cleaner, Heat Siphon pool heat pump, solar blanket, Ameri-Dome 50X30 dome enclosure during Winter.
    Puffin's Avatar
    Jul 2010
    217
    Thank you for the update. We are in the process of buying the home, we just passed the due-diligence period. We ended up finding someone nearby to inspect the pool. My family and I are looking forward to this summer =) and I've been reading the info on this site like crazy trying to learn everything I can.
